> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/release-notes.md).
# Release Notes
Please check our [Troubleshouting](/advanced-topics/troubleshooting.md) guide in case of problems when upgrading.
{% hint style="warning" %}
For existing projects with earlier realvirtual versions than 2022.15 please install first the package Update202215.unitypackage into your existing project for preparing the update (see below).
## Version History
> **⚠️ Important — Version Numbering System** To align with the Unity version numbering system and provide better traceability, we use the following numbering scheme:
> * **First two numbers** (e.g., `6.3`) match the Unity LTS base version (`6000.3.XX`).
> * The **third number** is our release counter.
> * **Changeset number** (e.g., `-8701`) provides exact source code traceability.
> * Format: **`6.3.0-8701`** where `8701` is the ever-increasing changeset number.
> * Changeset numbers always increase, providing clear chronological ordering.
**6.3.6-10298** — *6 October 2026* **Available for:** realvirtual **Professional & Starter** **Unity Support:** Unity 6000.3 LTS (Unity 6.3 LTS)
🚀 **New Features**
* **Move Pivot – Exact bore, shaft and cylinder centers from one click** – A new **Move to Circle / Bore Center** method determines the true center, axis and radius of a round feature on imported CAD from a single click on the surface. This closes a long-standing gap: bounding-box center, single vertex and triangle centroid all lie systematically beside the real center, because CAD tessellation is unevenly dense and any averaged position drifts toward the more finely tessellated area. The tool grows over the clicked surface, derives the axis from the face normals — which works regardless of whether the part is longer or wider than it is tall — and fits the circle numerically. The pivot can be placed at the clicked height, in the middle of the feature or at either end, and a local axis can be aligned to the detected axis in the same step, which is the fastest way to prepare a part for a rotational Drive. When no reliable circle can be determined the tool reports the reason instead of placing the pivot somewhere plausible. The same detection is available headless as the MCP tool `transform_circle_center`, so interactive and automated results are identical. See [Move Pivot Points](/basics/user-interface/move-pivot-points-pro.md) *(Professional)*
* **Ribbon (Web) Handling – Endless web over rollers, from unwinder to rewinder** – A new component family simulates paper, film, foil, textile or sheet metal running over rollers: **Ribbon Roller**, **Ribbon Winder**, **Ribbon Dancer** and **Ribbon Path**, ticked by one **Ribbon Manager**. The web is moved only by a rotational **Drive** on a roller, followers turn at `v / r`, winder diameters grow and shrink with the wound length, a dancer stores web between two sections, and a path can be slit into strips. While you place rollers, the Scene view shows the same solve as a live preview. The **Winder Speed Control** lets a winder follow the line speed or a dancer position, and the **Web Tension** model cuts the line into zones between driven rollers, computes strain, force and sag per zone, colours the band accordingly and reports **Tension N**, **Is Slack** and **Is Broken** as signals. Materials are picked by **name** from a **Ribbon Material Library** with an Inspector dropdown; a roller can optionally override its CAD materials at simulation start and gets them back at stop, and the GLB export carries the result into realvirtual WEB, where the same components run unchanged. Two samples, *DemoRibbonSlitter* and *DemoRibbonTension*, are included. See [Ribbon (Web) Handling](/components-and-scripts/motion/ribbon-handling.md) *(Professional)*
* **PLCSIM Advanced Interface – Data block tags on demand** – Variables in global data blocks can now be imported next to the process image. Enter the block names in the new **Import Data Blocks** list and the coupler loads exactly those blocks through the Siemens tag list filter; leave the list empty and only inputs and outputs are exchanged, as before. A data block tag has no inherent direction, so the signal component decides, exactly as in the S7 TCP/IP interface: newly imported tags are **PLCOutput** (read from the PLC); swap the component for the matching **PLCInput** to have the simulation write the tag. Requires *PLCSimAdvancedCoupler.exe* 6.1.11 or newer, which the setup downloads automatically. See [PLCSIM Advanced](/components-and-scripts/interfaces/plcsim-advanced.md#importing-data-block-tags) *(Professional)*
* **Modbus TCP Interface – Client and server in one interface** – A new **Modbus TCP** interface connects Unity signals to Modbus TCP devices in both directions. In **Client** mode Unity reads and writes the coils and registers of a PLC or I/O device (for example Inovance, Wago or Schneider); in **Server** mode Unity simulates a Modbus device that external masters such as a PLC, HMI or SCADA connect to. Addresses and data types are defined as signal metadata, identical to realvirtual WEB and CONNECT, and signal lists can be imported from CSV. The previous server-only interface remains available as *Modbus TCPRTU (Legacy)*, so existing scenes keep working unchanged. See [Modbus](/components-and-scripts/interfaces/modbus.md) *(Professional)*
* **PLCSIM Advanced Native Interface (Preview) – No external coupler process** – A second PLCSIM Advanced interface talks to the virtual controller in-process through a native plugin instead of the external coupler. It imports signals, re-synchronizes after a download from TIA Portal and handles pausing the Unity editor. See [PLCSIM Advanced Native](/components-and-scripts/interfaces/plcsim-advanced-native.md) *(Professional)*
* **Runtime Metadata – Part information from an Excel parts list** – The new **Excel Metadata Setup** creates the **Runtime Metadata** components for a complete CAD assembly from a parts list, so article numbers, technical data and document links no longer have to be entered part by part. At runtime the operator searches this information in a toolbar, and matching parts are highlighted and show their data in a window; the same content is exported to realvirtual WEB for hover tooltips and document links. See [Runtime Metadata](/components-and-scripts/scene-interaction/runtime-metadata.md) *(Professional)*
* **Performance Optimizer – Keep selected meshes out of the optimization** – The new **Performance Optimizer Exclude** component keeps the meshes of a GameObject, optionally including all children, out of mesh combining. They stay visible as they are and survive **Finalize Optimization** – useful for parts whose material or visibility changes at runtime or that scripts refer to. Parts below a **Runtime Interactable** are combined into a separate mesh of their own, so highlighting and picking them keeps working in an optimized scene. See [Performance Optimizer](/components-and-scripts/performance-tools/performance-optimizer-pro.md#keeping-meshes-out-of-the-optimization) *(Professional)*
✨ **Enhancements**
* **Signal Force Set – HMI pushbuttons apply and release a whole set** – A `SignalForceSet` can now be wired to HMI pushbuttons directly in the Inspector: **Apply Button** applies all enabled entries with one click and, with **Toggle With Apply Button** enabled, releases them on the next click; an optional **Release Button** only releases. While the set is active the apply button switches to **Button Active Color**, so the operator sees at a glance which force scenario is currently held. Force sets keep working for every signal direction, including PLC inputs that the simulation sends to the controller. See [Signal Force Sets](/components-and-scripts/interfaces/interface-tools/signal-force-set.md) *(Professional)*
* **HMI – Individual colors survive the UI skin** – HMI elements have a new **Use Skin Colors** option. Switched off, the active light or dark skin no longer overwrites **Color** and **Color Mouse Over** on play start, so pushbuttons and other HMI elements keep the colors set in the Inspector, for example red for acknowledge, blue for automatic and green for open *(Professional & Starter)*
* **MCP – Built-in components are readable and writable** – `component_get`, `component_get_all` and `component_set` now cover Unity's built-in components such as `RectTransform`, `Canvas`, `CanvasScaler`, `Image`, `Camera` and `Light`, which carry their state in properties instead of serialized fields. Simple property types (numbers, strings, enums, vectors, colors, rects) are returned, read-only properties are listed under `_readOnly`, and unknown or read-only keys are reported as errors instead of being ignored. Positioning HMI elements by anchors and sizes is therefore possible without an editor script *(Professional & Starter)*
* **MCP – `screenshot_game` can include the HMI overlay** – The new `includeUI` parameter renders Screen Space Overlay canvases through the capture camera, so the returned image shows the 3D scene together with the on-screen HMI. Canvases are restored to their original mode right after the capture *(Professional & Starter)*
* **Kinematic Joints – Drive axis validation** – The validation panel and `kinematic_doctor` now catch the single most common setup mistake in a kinematic mechanism: a `Drive` that moves its link about a different world axis than the joint it drives. Previously this produced a mechanism that looked correctly configured, converged cleanly in the solver and still moved wrongly, because the solver only reads the Drive's scalar position value while the Drive itself writes the link pose. Two new findings are reported before the first Play start, each with a one click **Fix**: **Drive Axis Mismatch** (axes differ in world space, including the sign — an anti-parallel axis on a driven joint displaces every downstream passive link by twice the angle) and **Drive Type Mismatch** (a linear Drive on a Revolute joint or vice versa). `Reverse Direction` is taken into account, and the fix sets both `Direction` and `Reverse Direction`. See [Kinematic Joints](/components-and-scripts/motion/kinematic-joints.md) *(Professional)*
* **PLCSIM Advanced – Signal import filter and much faster import** – Large PLC programs no longer have to be imported completely: with **Use Signal Filter**, include and exclude lists of regular expressions decide which signals are imported at all. Independently of the filter, creating the signal objects is now much faster – in a project with 12,000 signals, entering play mode went from several minutes to seconds. See [PLCSIM Advanced](/components-and-scripts/interfaces/plcsim-advanced.md) *(Professional)*
* **Cable – Direction Length for cable glands and clips** – A cable point can now hold the cable straight over a given length along its local Z axis. On an **Anchor** the cable is rigidly fixed in that direction, like in a cable gland; on a **Guide** the direction is held but the cable can still slide through, like in a clip. Cable points are shown with their own colored gizmos and can be selected and moved with the standard Unity tools. See [Cable](/components-and-scripts/motion/cable.md) *(Professional)*
* **Interfaces – Clean pause and resume** – Interfaces based on the FastInterface framework now close their connection when the Unity editor is paused, loses focus or leaves play mode, and reopen it on resume, instead of continuing to run in the background *(Professional & Starter)*
* **realvirtual WEB – Collision roles and chains from Unity** – The new **Web Collision Role** marker sets the collision role of a part for the collision detection in realvirtual WEB directly in the Unity scene, so it survives every re-export; a Source assigns a role to its MUs with **Collision Role For MUs**. Chains are now exported to realvirtual WEB as well, and the realvirtual WEB window shows the status of the connected realvirtual CONNECT gateway. See [Building a 3D-HMI](/extensions/realvirtual-web/3d-hmi.md#web-collision-role) *(Professional)*
🐛 **Bug Fixes**
* **MCP – Second Unity Editor no longer hides behind the first one** – When two editors with the MCP package run at the same time, the second one now moves to the next free port as intended. Previously the socket option that lets the bridge survive domain reloads also masked the port of the already running editor, so both instances reported port 18711 and every MCP call reached only the first editor *(Professional & Starter)*
* **realvirtual WEB – Instruction steps find targets with special characters again** – Fixed instruction and maintenance steps doing nothing when their target object carries a name with special characters (spaces, `:` or `.`) **and** occurs more than once in the CAD model: the step card appeared, but the object was not highlighted and the camera did not move to it. Such targets are highlighted and framed again — including in models that were exported before this version, without a re-export. A target that genuinely does not exist in the model is now reported on the step card, on the disabled view button and in the Problems panel instead of being ignored silently *(Professional)*
* **Drive – Jogging stops exactly at the jog speed** – Fixed a jogging Drive overshooting and oscillating around the jog speed after **Target Speed** was lowered while it was moving. Jogging with smooth acceleration was made more robust as well *(Professional & Starter)*
* **Drive – No more prefab overrides in edit mode** – Fixed Drives in prefab instances showing an override of the realvirtual controller reference as soon as the scene was edited *(Professional & Starter)*
* **Performance Optimizer – Scene Selectables survive the optimization** – Fixed the optimizer baking the renderers that a **Scene Selectable** refers to into the combined mesh and destroying them on **Finalize Optimization**, which broke selection and highlighting in the optimized scene *(Professional)*
* **Machining Volume – Colliders keep their size** – Fixed Box, Sphere and Capsule colliders on a workpiece shrinking when the Machining Volume bakes the transform scale into the workpiece – a scaled paper roll sank into the conveyor. A Mesh Collider cannot be adjusted automatically; the Inspector now shows a warning with the exact dimensions to use instead. See [Machining Volume](/components-and-scripts/machining-volume.md) *(Professional)*
* **PLCSIM Advanced Interface – Only active, imported inputs are written to the PLC** – Fixed the coupler writing every PLC input it knew, including signals that the import filter had excluded or that were set inactive in Unity, and writing zeros before Unity had published its first values. The shared-memory protocol now carries a write permission per signal and a handshake that is granted only after a complete data set, so excluding a signal from the import or disabling it really stops the write. Also fixed the last tag of the table being imported with the wrong data type, the coupler stalling the PLC after a Unity crash, and the tag list request failing with `NotEnoughMemory` on large safety projects — the coupler now requests inputs and outputs only and falls back to HMI-visible tags if the Siemens limit of 500 000 entries is still exceeded. The setup no longer copies the Siemens API DLL into StreamingAssets, because that copy shadowed the installed API; delete an existing copy. Coupler 6.1.12 serves older realvirtual versions unchanged *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/plcsim-advanced)
* **PLCSIM Advanced Interface – Large projects and 64-bit inputs** – Fixed the `-43 NotEnoughMemory` error on large projects, the last row of the signal table losing its data type, and 64-bit inputs (LINT, ULINT, LREAL) being transported incompletely. The coupler 6.1.12 also keeps serving realvirtual versions before 6.3.6 unchanged *(Professional)*
* **MU – No error for MUs created by script** – Fixed a NullReferenceException when an MU that was created at runtime with `AddComponent` (for example by a custom script) entered a sensor or got another MU loaded onto it *(Professional & Starter)*
* **Runtime Metadata – Preset search applied at start** – A search pattern preset in the **Metadata Manager** is now applied at play start, so the matching parts are highlighted and hoverable right away instead of only after the first search *(Professional)*
* **OPC UA Interface – Timeouts** – Fixed the connection timeout being interpreted in milliseconds instead of seconds, and the socket linger time is now limited to 60 seconds on macOS *(Professional)*
* **KUKA and Keba Interfaces – No false error on close** – Closing the interface no longer logs a communication error, and a threading issue in the KUKA interface is fixed *(Professional)*
* **GLB Export – No false renaming of same-named parts** – Fixed an export root and a direct child with the same name being reported as duplicates and renamed to `_rv1` / `_rv2`, a common pattern in CAD imports *(Professional)*
* **Package installation – Compiles in a new project** – Added the missing package dependencies `com.unity.behavior` (Starter) and `com.unity.modules.assetbundle` (Professional); without them the packages did not compile when installed into a clean project from the registry *(Professional & Starter)*
⚠️ **Known Issues**
* **Machining Volume – Occasional pinholes in the machined surface** – With the default **Marching Cubes** meshing, a machined surface can show a tiny hole of about one voxel at single spots in certain cut states. The material removal itself is correct; only the displayed surface has the gap. Switching **Meshing** to **Dual Contouring** avoids it. A fix is planned for the next version *(Professional)*
**Behavior change – signal names in realvirtual WEB.** A signal whose object name occurs more than once in the model and that has no explicit **Name** set is now registered under its original name (for example `MC04.01I00W`) instead of a stripped version (`MC0401I00W`). This is the spelling the control side (MQTT / realvirtual CONNECT) addresses, so signals of this kind become reachable. A layout planner binding that was saved **before** this version against such a signal shows up as orphaned afterwards and has to be bound again in the bindings overview. No signal in any of the project models we checked was affected.
**6.3.5-9348** — *13 July 2026* **Available for:** realvirtual **Professional & Starter** **Unity Support:** Unity 6000.3 LTS (Unity 6.3 LTS)
🚀 **New Features**
* **Kinematic Joints – Deterministic parallel kinematics** – A new, purely kinematic constraint solver (`KinematicJoint`/`KinematicMechanism`, menu **realvirtual/Kinematics**) solves closed kinematic chains — Delta robots, four-bar linkages, scissor lifts, parallel grippers — without Unity physics, jitter or drift. Existing `Drive` components keep driving the active joints exactly as before; the solver moves every passive link to satisfy the mechanism's constraints each FixedUpdate, with live Converged/Residual Error diagnosis and an Edit Mode "Solve Now" preview. See [Kinematic Joints](/components-and-scripts/motion/kinematic-joints.md) *(Professional)*
* **FMI / FMU Interface – Co-simulation with 150+ engineering tools, completely rebuilt** – The FMI interface is back, rebuilt from scratch on a new high-performance native co-simulation core (the previous integration was deprecated). Load **FMI 2.0 Co-Simulation** FMUs exported from Modelica, Dymola, Simulink, Amesim and 150+ other tools, and couple validated physics and controls models — hydraulic axes, electrical drives, controllers — directly into your scene. One click on **Import Signals** creates all FMU inputs, outputs and tunable parameters as ordinary realvirtual PLC signals in Edit Mode, initialized with the FMU's own start values and ready to wire to Drives and Behaviors. The FMU steps in exact sync with the Unity physics timestep (pause and time scaling included), with an optional free-running mode for faster-than-realtime co-simulation. FMU files live in `StreamingAssets/FMU/` and ship with your builds. See [FMI / FMU](/components-and-scripts/interfaces/fmi.md) *(Professional)*
* **Machining Volume & Machining Tool – Real-time material removal** – Simulate CNC milling, drilling and grinding with real-time, voxel-based material removal: a **MachiningTool** carves a **MachiningVolume** workpiece (box, cylinder, or any closed mesh as stock) with watertight, continuously updated live geometry. Multiple tools, PLC **Reset** and **Machining Active** signals, and a two-station demo scene (CSG Machining sample) are included. See [Machining Volume](/components-and-scripts/machining-volume.md) and [Machining Tool](/components-and-scripts/machining-tool.md) *(Professional)*
✨ **Enhancements**
* **Fanuc Interface – Multi-robot cells and background operation** – The Fanuc interface now has a **Port** field, so a ROBOGUIDE cell with several virtual robots on one PC works. Add one Fanuc interface per robot, all on the same address (`127.0.0.1` for a local ROBOGUIDE), with the robot's Robot IF port — ROBOGUIDE assigns an incrementing port per virtual robot (robot 1 = `60008`, robot 2 = `60009`, …), as listed in each `robot_x/services.txt` of the workcell. The connection now also keeps running and exchanging signals while the Unity window is in the background *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/fanuc-pro)
* **User Hub – Package updates work behind TLS-inspection proxies** – When a package update from the realvirtual registry fails with a certificate error — typical in corporate networks where a TLS-inspection proxy replaces the server certificate, which the Unity Package Manager rejects — the User Hub now falls back automatically to a direct download using the operating system trust store and installs the package as a local tarball. Activating the registry again switches the package back to registry-based updates once the registry is reachable *(Professional)* - [Documentation](https://doc.realvirtual.io/login-and-download-updates-pro)
* **User Hub – One-click package install from Downloads** – UPM package tarballs in the **Downloads** tab now have an **Install** button that downloads the package and installs it directly into the open project — no manual **Package Manager → Add package from tarball** step needed. The status line below the file list shows download progress and the installation result *(Professional)* - [Documentation](https://doc.realvirtual.io/login-and-download-updates-pro)
* **Robot Program Export – Real SEW MOVI-C robot program (.srlprg)** – The SEW target now exports an actual runnable MOVIKIT Robotics sequence program (`.srlprg`) instead of the previous CSV point table / IEC 61131-3 ST template. It emits the native SEW program form: a header with `KINEMATIC` and `MotionSet`, a `REALVAR` I/O init block (one slot per signal used in the program), the dynamic-values and blending setup, and a main program of `PTP_J` (joint), `LIN` (Cartesian `X/Y/Z` + `RotZ/RotY/RotX`), signal writes and `WAIT_TIME`. The controller kinematic number and MotionSet are configurable in the export window. As with the other targets this is an offline copy-paste template — validate on the (virtual) MOVISUITE controller before running on hardware *(Professional, Beta)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/robot-program-export)
🐛 **Bug Fixes**
* **EtherNet/IP Interface – All input signals now written to the PLC** – Fixed only the first PLC input signal under the interface (Unity → PLC) being transmitted to Allen-Bradley controllers, while all other inputs silently never updated the PLC. The internal write-tag connections were only initialized for the first tag, so writes to all remaining tags failed before reaching the controller. Write tags are now initialized on demand, so every input is transmitted regardless of its position in the hierarchy. Reading outputs from the PLC was not affected *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/ethernetip)
* **Fanuc Interface – Signals mapped by name, not list position** – Fixed robot I/O being matched by the position of the signal in the interface list instead of by signal name, so a digital output could drive the wrong Unity signal — the robot's `DO3` switched the third GameObject in the list rather than the signal named `do3`, and outputs shifted whenever the list order or numbering had gaps. Signals are now matched strictly by name (`do4` → `do4`), independent of ordering and of gaps in the numbering (e.g. `do1`, `do3`, `do4`). Also fixed safety digital outputs (SDO) being written to the wrong signal table and uninitialized handling of user input (UI) signals *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/fanuc-pro)
* **PLCSIM Advanced Interface – Robust across API versions and survives TIA downloads** – The coupler now loads automatically with a compatible PLCSIM Advanced API version. The same build connects whether an older PLCSIM Advanced installation or a current V8 runtime is used, fixing the `MissingMethodException` and initialization errors seen on newer installations. It also no longer terminates when a changed program is downloaded from TIA Portal onto the running PLC: signal exchange pauses during the download and the interface reconnects and re-imports the (possibly changed) signals automatically. A `coupler.log` next to the executable records the loaded API version, the running Runtime Manager version and any errors for easy diagnosis *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/plcsim-advanced)
* **Siemens Simit Interface – Signal list reliably written on play and build** – Fixed `SimitSignalList.xml` being written empty. The SIMIT SDK writes the signal list when you enter play mode or build, but the signals were only registered at runtime afterwards, so the list was written before it was populated. It then only appeared after a later scene save, for example when closing Unity. The signals are now registered before the SDK writes the list, so it is reliably present and up to date at play start and in builds. The list is also re-synced when child signals are added, removed, renamed or retyped *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/siemens-simit-interface-pro)
* **Festo AX Controls (PLCnext) Interface – Signals now update reliably** – Fixed PLC output signals staying at their initial value while the interface reported a healthy connection. The variable import flattened the GDS path separator between component and port to a dot (e.g. `Codesys.Gds.0.POU.dXPos`), which the controller rejected; the correct `/` separator is now used and existing signals are repaired automatically (e.g. `Codesys.Gds/0.POU.dXPos`). Controllers that do not implement RSC subscriptions (Festo AX / CODESYS GDS) now fall back to direct polling automatically instead of silently receiving no data. Subscription values are mapped to the correct signals via the controller-reported variable order, and rejected variables or failed subscribe/read calls are now logged instead of swallowed *(Professional, Beta)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/festo-plcnext)
* **Professional License Login – More robust in corporate networks** – The Professional login now retries automatically on transient server errors, supplies the system proxy credentials so authenticating corporate proxies no longer block sign-in, and shows a clear message when a proxy or firewall blocks the license server instead of a generic error code. Unexpected responses are written to the Editor console to speed up diagnosis *(Professional)*
* **Fixer – No more NullReferenceException on non-MU objects** – Fixed a `NullReferenceException` in `Fixer.OnTriggerEnter` when a collider without an MU in its hierarchy entered the Fixer (for example plain scene geometry combined with a tag filter). The Fixer now ignores colliders that do not belong to an MU instead of throwing - [Documentation](https://doc.realvirtual.io/components-and-scripts/picking-and-placing-mus/fixer)
* **Sensor – No longer detects other sensors** – Fixed sensors reporting each other as occupied. Sensors live on the `rvSensor` layer, which collides with itself in the collision matrix, so two overlapping sensor volumes registered one another as a detected object. A sensor now ignores colliders that belong to another Sensor - [Documentation](https://doc.realvirtual.io/components-and-scripts/sensors/sensor)
* **Group Assignment Tool – Prefix-based groups handled correctly** – Fixed assigning objects to a group that uses a **Group Name Prefix** baking the combined name (prefix + group name) into the plain group name field instead of replicating the prefix. Renaming the prefix object or reusing the prefab then changed the effective name of the original members while the newly assigned object kept the baked string, silently dropping it out of the group. The tool now copies the prefix and raw group name from the existing group, so prefab-based, prefix-differentiated stations stay consistent *(Professional)* - [Documentation](https://doc.realvirtual.io/basics/user-interface/group-assignment-tool-pro)
* **Grip – Place Align With Object now aligns rotation, plus physics options** – Fixed **Place Align With Object** being ignored in the current place flow, so the placed MU kept the gripper's rotation instead of aligning to the target. Alignment is now applied on every place path, with separate **Place Align Position** and **Place Align Rotation** toggles (as on the Fixer). A new **Release Constraints When Placed** option additionally clears the MU's Rigidbody constraints when placing with physics, for cases where the gripped part had frozen axes - [Documentation](https://doc.realvirtual.io/components-and-scripts/picking-and-placing-mus/grip)
* **Scene Selectables – Tooltip no longer lingers on fast hover-out** – Fixed the hover tooltip staying on screen when the mouse left a selectable quickly or moved straight onto a UI element. A delayed tooltip re-activation could fire one frame after the hover had already ended, and moving onto UI skipped the hover reset; both paths now clear the tooltip reliably *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/scene-interaction/scene-selectables-pro)
* **Drive\_SEWMovilink – Correctly scoped to the legacy MOVILINK generation** – Fixed the documentation and component description incorrectly listing **MOVI-C** as a MOVILINK device. MOVILINK is the legacy SEW unit profile of the MOVIDRIVE B / MOVITRAC B / MOVIMOT generation; MOVI-C does not use MOVILINK but the MOVIKIT process data profile or PROFIdrive / CiA 402. The behavior model itself (control-word / status-word logic, `0x06` enable byte) is unchanged and correct — for a MOVI-C drive in CiA402 mode use `Drive_CiA402` instead *(Professional, Beta)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/drive-behavior)
**6.3.4-9151** — *12 June 2026* **Available for:** realvirtual **Professional & Starter** **Unity Support:** Unity 6000.3 LTS (Unity 6.3 LTS)
🚀 **New Features**
* **Signal Force Sets (Pro)** – Force boundary signals (voltage, e-stop, pressure, operating mode) to defined values for virtual commissioning, switch between test scenarios by applying or releasing named sets, and monitor all active forces in a dedicated Signal Force Monitor window — equivalent to the force table in TIA Portal / TwinCAT *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/signal-force-set)
* **Group Assignment Tool** – Scene-picking tool to assign GameObjects to groups by click, drag-paint, or Select-Connected flood-fill directly in the Scene View. Complements the hierarchy-based Selection Window and axis-based Kinematic Tool for rapid bulk assignment *(Professional)* - [Documentation](https://doc.realvirtual.io/basics/user-interface/group-assignment-tool-pro)
* **PLC-Accurate Drive Behavior Models (Beta)** – New drive behaviors that mirror the exact control-word / status-word process image of real PLC drives, so a drive only moves once the PLC has stepped it through the standard enable sequence: **Drive\_ProfidriveSpeed** and **Drive\_ProfidrivePos** (Siemens PROFIdrive / SINAMICS G120, S120, V90 – standard telegram 1 and raw telegram 111), **Drive\_CiA402** (CiA 402 / DS402 – EtherCAT CoE and CANopen: Beckhoff, Kollmorgen, Lenze, SEW MOVI-C, Bosch Rexroth ctrlX DRIVE …), **Drive\_SEWMovilink** (SEW MOVILINK), **Drive\_FestoFHPP** (Festo FHPP), **Drive\_UniDriveMotor** (generic control-word positioner) and **Drive\_ProportionalValve** - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/drive-behavior)
* **Runtime Environment Lighting** – The Environment Controller now computes the skybox ambient and reflection live at runtime, so scenes are correctly lit without baking. Per-scene baked lighting folders (`LightingData.asset`, `ReflectionProbe-*.exr`) become optional, and a new **Tools > realvirtual > Settings > Remove Baked Lighting Folders** utility removes them safely after a confirmation warning — slimming projects and ending the version-control noise these binary files cause after every bake - [Documentation](https://doc.realvirtual.io/components-and-scripts/game4automation/environment-controller)
* **Robot Program Export (Beta)** – Turns a taught IK Path into ready-to-paste controller code: **ABB RAPID** (`.mod`), **KUKA KRL** (`.src`/`.dat`), **Fanuc TP/LS** (`.ls`), **SEW MOVI-C / MOVIKIT** (CSV point table or IEC 61131-3 ST template) and **Wandelbots NOVA** (Python SDK or Wandelscript). Offline copy-paste workflow (no live upload) with axis-based or Cartesian output, live preview and Copy / Save File, available from **Tools > realvirtual > Robot Program Export** or the IK Path inspector. The output is a copy-paste **template** — validate on a (virtual) controller before running on hardware *(Professional, Beta)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/robot-program-export)
✨ **Enhancements**
* **SIMIT Auto Update Signals** – The SiemensSimitInterface now re-exports the SIMIT signal list automatically (debounced) whenever you add, remove, rename or retype a child signal in edit mode and on scene save, so the mapping stays in sync without manual steps. A **Refresh Simit Signals** button remains available for manual export *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/siemens-simit-interface-pro)
* **Robot IK – Solution Picker** – The IK Solutions list now keeps a stable order and shows, per solution, the largest single-axis move to the previous path point (maxΔ) with a **SMOOTH** marker for the lowest-motion configuration, so you can see which solution gives a smooth path and pick it yourself. Clicking a solution pins it by joint angles, so the chosen configuration is stably restored on every re-solve *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/robot-inverse-kinematics)
* **Robot IK – Smoother motion** – Joint angles are now kept continuous automatically (the solver picks the angle representation closest to the current pose within the axis limits), avoiding 360° / -180°↔+180° wrist-flip jumps during linear and point-to-point motion *(Professional)*
* **Robotics Demo** – The standard IK demo (DemoRobotIK) now demonstrates both a standard 6-axis robot (ABB IRB2400, spherical wrist) and a collaborative robot (FANUC CRX, non-spherical wrist) in one scene *(Professional)*
🐛 **Bug Fixes**
* **Standard Demo (DemoRealvirtual)** – The bundled Getting Started sample now ships the up-to-date DemoRealvirtual scene in which the robot reliably grips and places the turbine onto the outgoing conveyor.
* **Robot IK – Collaborative robots** – Fixed an IndexOutOfRangeException that could occur when an IK target carried a solution index left over from a different seed configuration *(Professional)*
* **Robot IK – Synchronized PTP speed** – Fixed robot paths gradually slowing to a crawl: synchronized point-to-point moves and zone blending could progressively overwrite and re-save an already-reduced axis speed. Axis speed and acceleration are now captured once and reliably restored *(Professional)*
* **Siemens Simit Interface** – Fixed duplicate signal entries being written to `SimitSignalList.xml` when a deactivated interface (Active set to Never) was present in the scene, for example alongside a SignalCatcher. An interface set to Never no longer enables its coupler or runs signal initialization, so it can no longer trigger a second signal-list export. Each signal is now written to the XML exactly once *(Professional)*
* **Unity 2022.3 / Tuanjie Editor compatibility** – Resolved compile and shader errors that prevented the packages from building on Unity 2022.3-based editors such as the Tuanjie Editor (团结引擎). Unity-6-only Rigidbody APIs are now version-guarded, the Multi-Object Outline render feature is compatible with URP 14, an unsupported dedicated-server build target was removed from the CADLink assembly, and the Mitsubishi MC Protocol interface is gated behind the `REALVIRTUAL_MITSUBISHI` define on non-Unity-6 editors. Behavior on Unity 6 is unchanged.
**6.3.3-9052** — *22 May 2026* **Available for:** realvirtual **Professional & Starter** **Unity Support:** Unity 6000.3 LTS (Unity 6.3 LTS)
🚀 **New Features**
* **Festo AX Controls / PLCnext Interface (Beta)** – New interface for Festo AX Controls controllers running PLCnext Technology. Connects via the RSC (Remote Service Call) library over TCP, with subscription mode for real-time push-based signal exchange and polling mode as fallback. Includes editor button for one-click variable import from the PLC. See [Festo AX Controls (PLCnext)](/components-and-scripts/interfaces/festo-plcnext.md) *(Professional)*
* **Mesh Tools** – New tabbed editor window combining mesh utilities for CAD workflows. **Mesh Separator** splits combined meshes into individual disconnected islands with color-coded Scene view preview and selective separation. **Auto Correct Pivots** fixes off-center mesh origins from CAD imports by recentering vertices and compensating transforms. See [Mesh Tools (Pro)](/basics/user-interface/mesh-tools.md) *(Professional)*
* **Lamp** – Visual status indicator for HMI and signaling. Drives emission color and intensity via a MaterialPropertyBlock (batching preserved), with flashing, an optional point light, and PLC control through `SignalLampOn` and `SignalLampFlashing`
✨ **Enhancements**
* **Group Collision Detection** – Collision PLC signals are now shown as connected in the inspector. Movable Units (MUs) are checked through dedicated child trigger colliders so their functional layers (rvMU, transport, sensor) stay intact, the collision layer reliably collides with itself, and managed colliders are visualized with Scene view gizmos *(Professional)*
* **ctrlX CORE Interface** – Added device status, bridge health monitoring, snap log viewing, Data Layer settings, and bridge configuration management via REST API and WebSocket config messages *(Professional)*
* **Chain Conveyor** – Chain path can now be defined with Unity Splines
🐛 **Bug Fixes**
* **Grip Auto-Place on Conveyors** – Fixed placed parts staying kinematic instead of being transported away. This affected the **standard demo scene** (DemoRealvirtual), where the robot places turbines on the outgoing conveyor. The Grip Auto-Place surface raycast now fires straight down in world space instead of along the gripper's local up axis — grippers with an arbitrarily oriented tool axis previously missed the conveyor below, leaving placed MUs kinematic. Placed MUs now correctly get physics enabled and are transported on the surface
* **Move Pivot Tool** – Fixed Scene view callback handling that caused vertex selection and preview gizmos to stop working after picking points, cancelling, or pressing Escape. The Scene GUI handler is now subscribed once and properly cleaned up when the tool closes. Each pivot method now also shows a contextual hint explaining how to use it *(Professional)*
* **Group Visibility** – The runtime Group Manager is now null-safe against destroyed Group components, so short-lived MUs that carry a Group no longer cause errors
**6.3.2-8944** — *2 May 2026* **Available for:** realvirtual **Professional & Starter** **Unity Support:** Unity 6000.3 LTS (Unity 6.3 LTS)
### Starter & Professional
🚀 **New Features**
* **Group Collision Detection** – Runtime collision checking between named groups (e.g., robot vs. fixture) with GPU-accelerated highlighting, PLC signal output, automatic collider setup modes (Box/Mesh/Existing), and per-group self-collision filtering *(Professional)*
* **Statistics LogicSteps** – Four new LogicStep components (`LogicStep_StatState`, `LogicStep_StatOutput`, `LogicStep_StatStartCycle`, `LogicStep_StatEndCycle`) for integrating state tracking, output counting, and cycle time measurement into automation sequences *(Professional)*
✨ **Enhancements**
* **Drive Position/Speed Overwrite** – New `PositionOverwrite` and `SpeedOverwrite` properties allow external systems to directly set drive state for replay and multiuser synchronization
* **Grip Auto-Place with GripTarget** – Enhanced Grip with three-mode placement (Auto/Static/Physics), automatic GripTarget detection via OverlapSphere, MU-on-MU loading support, and OverlapSphere pick when no sensor is assigned
* **Network Ownership Framework** – `realvirtualBehavior` base class now includes `IsNetworkOwner`, `SetNetworkOwner()`, and `OnOwnershipChanged()` virtual callback for multiuser authority management across all components
* **Fixer Multiuser Support** – Fixer now implements IMultiPlayer interface for multiuser client/server mode awareness, preventing unwanted fix/unfix operations on remote-controlled components
* **NetworkPlayer Performance** – NetworkPlayer optimized to only sync name when it actually changes, preventing unnecessary writes per frame *(Professional)*
* **GLBManager Batch Export** – Thread-safe batch export with aggressive import blocking to prevent Unity re-import during multi-file exports *(Professional)*
* **CADLink Native Importer** – Updated CMC-Kiesel DLLs for JT format improvements *(Professional)*
🐛 **Bug Fixes**
* **ModelChecker State Persistence** – Fixed state loss across play mode transitions by using EditorPrefs for persistence
* **OPC-UA Subscription Stability** – Improved LibUA encoding layer stability for long-running subscription sessions *(Professional)*
**6.3.1-8780** — *24 March 2026* **Available for:** realvirtual **Professional & Starter** **Unity Support:** Unity 6000.3 LTS (Unity 6.3 LTS)
🚀 **New Features**
* **Time-Synced Physics Interface** – New `ITimeSyncedPhysics` interface enabling external time sources to control Drive and TransportSurface physics updates with custom delta time instead of Unity's fixed timestep. Enables precise co-simulation synchronization with external tools
* **HDRi Skybox Environments** – New autoshop and empty warehouse HDRi skybox presets for realistic industrial lighting
* **Enhanced Mesh Gizmo Visualization** – Reworked pivot and center point gizmos with proper RGB axis systems, cone tips, colored markers (sphere for pivot, cube for center), optional labels, and a new bounding-box mode as lightweight alternative to full wire mesh rendering
✨ **Enhancements**
* **Editor Group Lookup Performance** – All group lookups across the codebase now use a centralized cached group system (`Groups.GetCachedGroups()`) that includes inactive objects and auto-invalidates on hierarchy or play mode changes, eliminating repeated expensive FindObjectsByType calls
* **QuickToggle Signal Display** – Signals without interface mappings are no longer incorrectly grayed out in the hierarchy, improving visibility for LogicSteps and behavior-only usage. Selection-based signal highlighting now uses a cached HashSet for better performance
* **DriveHandle Scene GUI Performance** – Drive limit label style is now cached instead of being allocated every frame during scene rendering
🐛 **Bug Fixes**
* **Grip NoPhysicsWhenPlaced** – Fixed an issue where MUs placed with NoPhysicsWhenPlaced mode would have physics re-enabled, causing them to fall or behave unexpectedly. Placed MUs now correctly remain kinematic
* **Grip PickedMUs Initialization** – Fixed potential null reference when PickedMUs list was accessed before Start()
* **S7 Interface Reconnection** – Fixed socket leaks on reconnect, thread-unsafe logging from background thread, and communication thread being killed on disconnect preventing proper reconnection
* **TransportSurface Group Name** – Fixed 5 locations using raw GroupName field instead of GetGroupName(), causing incorrect bounds, renderer, and collider lookups for kinematic-integrated transport surfaces
* **igus REBEL Interface** – Fixed off-by-one error in signal numbering and added missing CMD prefix to GSIG command
* **GroupManager Inspector** – Fixed DisableMeshOnHide property visibility in Inspector and mesh hiding to work independently of DisableGameObjectOnHide
### Professional Only
🚀 **New Features**
* **Siemens Simit Time-Synchronized Physics** – The Simit interface now supports physics time synchronization via the ISimulator interface. When AllowTimeSync is enabled, Simit controls Unity physics timesteps directly for deterministic co-simulation *(Professional)*
✨ **Enhancements**
* **OPC-UA Thread-Safe Subscriptions** – Subscription value callbacks are now processed on the Unity main thread via a ConcurrentQueue, eliminating cross-thread access and preventing crashes during high subscription update rates *(Professional)*
* **Kinematic Tool Axis Gizmos** – Context-aware gizmos showing rotation arcs with limit indicators for rotational axes and directional arrows with limit markers for linear axes. Colors configurable via EditorGizmoOptions *(Professional)*
* **Kinematic Tool UI Improvements** – Visual grouping for Parts and Drives sections, hierarchy click integration, keyboard shortcuts (Ctrl+D, Ctrl+R, Esc), and selection filtering to prevent accidental axis/controller selection *(Professional)*
* **StateStatistics Performance** – Zero-GC rewrite with lazy inspector updates, cached DES.Now delegate, O(1) HashSet free-state lookups, and manual sorting replacing LINQ *(Professional)*
🐛 **Bug Fixes**
* **Licensing Play Mode Guard** – Fixed licensing validation during play mode *(Professional)*
* **OPC-UA Subscriptions** – Fixed unlimited subscriptions when MaxNumberOfNodesPerSubscription=0, null signal reference guard, and stale values cleared on disconnect *(Professional)*
* **Kinematic Tool** – Fixed point-to-point line drawing, multiple null references after domain reload, repaint loop causing editor performance issues, and memory leaks from static references *(Professional)*
**6.0.11-8732** — *13 March 2026* **Available for:** realvirtual **Professional** **Unity Support:** Unity 6000.0.28f1 and upwards (Unity 6) and Unity 2022 LTS
This is a \*\*maintenance release\*\* for existing Unity 6.0 projects. For new projects, we recommend using \*\*realvirtual 6.3\*\* which targets Unity 6000.3 LTS.
✨ **Enhancements**
* **Editor Performance Optimization** – Eliminated editor lag when selecting GameObjects with Kinematic, Drive, or other realvirtual components. Introduced a central Group cache with smart invalidation across 18+ locations that previously called FindObjectsByType every frame. Fixed repaint loops in KinematicTool, added selection-based signal caching in QuickToggle, and cached GUIStyle in DriveHandle *(Professional)*
* **LogicStep DriveTo Direction Control** – Added Direction option (Automatic, Forward, Backward) to LogicStep\_DriveTo for explicit movement direction control on 360° continuous rotation drives. Allows specifying which way the drive should rotate when crossing the 360°→0° boundary *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/defining-logic/logicsteps)
🐛 **Bug Fixes**
* **igus iRC Thread Safety** – Fixed multiple race conditions in igus iRC Interface that caused InvalidOperationException crashes. Replaced List with ConcurrentQueue for signal synchronization, moved thread start after signal setup, added lock on SendCommand to prevent TCP message corruption, dispatched EXECEND handler to main thread via volatile flag, and added null-guard to CloseInterface *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/igus-rebel)
* **igus iRC Digital I/O** – Fixed FormatException preventing digital I/O initialization when Signal.Name is empty. Restored numoutput counter fallback for correct Mempos assignment of DOut and GSig signals *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/igus-rebel)
* **Scene Selectables** – Fixed NullReferenceException on hover and click interactions by correcting a compiler directive mismatch that prevented OutlineSelectionManager and OverlaySelectionManager from compiling as AbstractSelectionManager *(Professional)*
* **GroupManager Hide** – Fixed groups not hiding when DisableMeshOnHide is enabled but DisableGameObjectOnHide is disabled. Corrected if/else logic and fixed the ShowIf attribute so DisableMeshOnHide is visible in the Inspector when needed *(Professional & Starter)*
* **CAD Checker Triangle Count** – Fixed CAD Checker displaying triangle counts 3x higher than actual values. mesh.triangles.Length returns index count which must be divided by 3 to get the correct triangle count *(Professional)*
* **Siemens Simit Time-Synced TransportSurfaces** – Fixed TransportSurfaces not moving in Simit time-synced mode. TransportSurface now implements the new ITimeSyncedPhysics interface and registers with the realvirtualController for externally driven physics updates, ensuring correct conveyor motion when Simit controls the simulation timestep *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/simit-shared-memory)
* **Siemens Simit Interface** – Improved documentation and added validation for the SimitConnection field assignment *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/siemens-simit-interface-pro)
**6.0.11-8732** — *13 March 2026* **Available for:** realvirtual **Starter** **Unity Support:** Unity 6000.0.28f1 and upwards (Unity 6) and Unity 2022 LTS
✨ **Enhancements**
* **LogicStep DriveTo Direction Control** – Added Direction option (Automatic, Forward, Backward) to LogicStep\_DriveTo for explicit movement direction control on 360° continuous rotation drives *(Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/defining-logic/logicsteps)
🐛 **Bug Fixes**
* **igus iRC Thread Safety** – Fixed multiple race conditions in igus iRC Interface that caused InvalidOperationException crashes *(Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/igus-rebel)
* **igus iRC Digital I/O** – Fixed FormatException preventing digital I/O initialization when Signal.Name is empty *(Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/igus-rebel)
* **GroupManager Hide** – Fixed groups not hiding when DisableMeshOnHide is enabled but DisableGameObjectOnHide is disabled *(Starter)*
**6.3.0-8701** — *8 March 2026* **Available for:** realvirtual **Professional & Starter** **Unity Support:** Unity 6000.3 LTS (Unity 6.3 LTS)
🚀 **New Features**
* **UPM Package Distribution** – realvirtual is now distributed as standard Unity Package Manager (UPM) packages (`io.realvirtual.starter`, `io.realvirtual.professional`). Install and update via the realvirtual Package Manager window with automatic dependency resolution between packages - [Documentation](https://doc.realvirtual.io/basics/installation)
* **Unity 6.3 LTS** – First release targeting Unity 6000.3 LTS (Unity 6.3). Updated render pipeline settings, URP compatibility, and leverages Unity 6.3 APIs throughout
* **LogicStep GripPick & GripPlace** – Two new logic step components for direct Grip control in automation sequences. GripPick triggers a pick with optional blocking mode (waits until MU is gripped), GripPlace triggers a place operation. Both include safety timeouts - [Documentation](https://doc.realvirtual.io/components-and-scripts/defining-logic/logicsteps)
* **LogicStep StartDriveTo** – Non-blocking drive-to command that starts the motion and immediately proceeds to the next step. Use with LogicStep\_WaitForSignalBool on the drive's AtPosition signal to create parallel drive motion sequences - [Documentation](https://doc.realvirtual.io/components-and-scripts/defining-logic/logicsteps)
* **LogicStep SetActiveOnly** – New logic step that sets a GameObject active without optionally deactivating it on the next step (unlike LogicStep\_Enable which toggles). Useful for one-shot activations in automation sequences - [Documentation](https://doc.realvirtual.io/components-and-scripts/defining-logic/logicsteps)
* **Component Validation System** – Automatic validation framework that discovers rules through reflection and executes them when components are added, removed, or before entering play mode. Built-in rules: prevent duplicate Drives, validate TransportSurface hierarchy and mesh, check BehaviorInterface jogging setup. Extensible with custom ValidationRule\<T> classes - [Documentation](https://doc.realvirtual.io/components-and-scripts/game4automation/pre-play-validation)
* **Demo Scenes Browser** – New categorized Demo Scenes window with visual browser for all sample scenes. Categories include Getting Started, Motion, Gripping, Sensors, Interfaces, and Robotics. One-click scene import and loading with documentation links - [Documentation](https://doc.realvirtual.io/basics/user-interface/demo-scenes-browser)
* **MCP Server Support** – Built-in domain-specific MCP tools for AI agent integration. Includes tools for Drives, Sensors, PLC Signals, MUs, LogicSteps, and Scene Notes — enabling AI agents like Claude to build and control digital twin simulations in real time. Works with the free [realvirtual MCP Server](https://doc.realvirtual.io/extensions/mcp-server) package - [Documentation](https://doc.realvirtual.io/extensions/mcp-server)
✨ **Enhancements**
* **Grip Auto-Place System** – Enhanced Grip component with intelligent auto-place raycast: GripTarget → align+parent, MU below → LoadMu, TransportSurface → Physics, else → Kinematic. Three PlaceMode options (Auto, Static, Physics). OverlapBox pick with pre-allocated collider buffer for zero GC allocations - [Documentation](https://doc.realvirtual.io/components-and-scripts/picking-and-placing-mus/grip)
🐛 **Bug Fixes**
* **MU Component** – Fixed component lifecycle and state management issues
* **Sensor Detection** – Improved detection reliability and event firing consistency
* **Drive Cylinder** – Fixed position calculation edge cases
🚀 **New Features**
* **License Registration via User Hub** – Professional edition now requires license registration through the realvirtual User Hub directly inside Unity - [Documentation](https://doc.realvirtual.io/login-and-download-updates-pro)
* **Non-Spherical Wrist IK (BETA)** – New IK solver supporting cobots with non-spherical wrists (e.g. FANUC CRX, UR-type robots). Uses Pieper analytical solution refined by Newton-Raphson iterations with numerical Jacobian. Features mirrored seed generation (8 additional wrist-flip seeds), Halton low-discrepancy fallback seeds for hard-to-reach poses, configurable NR damping and convergence tolerances, and diagnostic logging - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/robot-inverse-kinematics)
* **IK Zone Blending (Überschleifen)** – Smooth robot path transitions without stopping at intermediate targets. Configurable blend radius per IKTarget enables the robot to begin moving toward the next waypoint within the specified distance. Supports LIN→LIN circular arc blending, PTP→PTP blending, and PTP→LIN transitions with TCP velocity preservation. Eliminates jerky motion at waypoints for faster cycle times - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/robot-inverse-kinematics)
* **IK Solution Selection Modes** – New SolutionSelectionMode enum with FirstReachable (default, backward compatible) and MinimalAngleChange (prefers solution minimizing total joint angle delta from current position). Solutions are now sorted by proximity to reference angles from the previous path target - [Documentation](https://doc.realvirtual.io/components-and-scripts/robot-inverse-kinematics)
* **ctrlX CORE Interface** – New interface for Bosch Rexroth ctrlX CORE devices. Extends WebSocket Realtime with device status monitoring (firmware, operating state), bridge health checks (snap status, version, uptime), log viewer, Data Layer settings, and bridge configuration via REST API. Full bidirectional signal exchange over the ctrlx-rv-bridge - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/ctrlx)
✨ **Enhancements**
* **IK Burst Compiler Optimization** – IKCalculatorBurst now uses Unity.Mathematics SIMD operations and Unity Jobs for parallel IK computation. Async job scheduling prevents main thread blocking. Profiler markers added for performance analysis
* **IK Gizmo Visualization** – Enhanced scene view gizmos showing TCP marker, DH kinematic chain with segment lengths, joint positions as needles within limit arcs, local coordinate frames with rotation direction, and wrist type indicator (sphere for spherical, offset visualization for non-spherical)
* **WebSocket Realtime Interface Refactoring** – Rebuilt on FastInterfaceBase for thread-safe background communication with automatic reconnection, change detection, and flat JSON wire protocol (v2). Per-client subscribe filtering and fast-path broadcast. Signal import creates local mirror signals with inverted direction
* **Grip Integration with IKTarget** – IKTarget now supports direct Grip component reference (gripTarget field) as modern alternative to Fixer. Grip takes priority when both are assigned - [Documentation](https://doc.realvirtual.io/components-and-scripts/robot-inverse-kinematics)
🐛 **Bug Fixes**
* **IK Edit Mode Jitter** – Eliminated solution flickering in edit mode by caching last-solved target state and preventing redundant IK resolves when target hasn't moved
* **EthernetIP Interface** – Fixed connection handling and signal mapping issues
* **Keba Interface** – Improved signal synchronization reliability
**6.0.10-8590** — *15 February 2026* **Available for:** realvirtual **Professional** **Unity Support:** Unity 6000.0.28f1 and upwards (Unity 6) and Unity 2022 LTS
🚀 **New Features**
* **igus iRC Interface** – Completely rewritten interface now supporting variable axis counts (1–9 axes) for all igus robot kinematics including ReBeL 6DOF, SCARA 4DOF, delta robots, and linear robots. Adds Fair-version features: inverse kinematics via CRI, position-based motion with RebelTarget, async motion commands, speed control, digital I/O, and OnMoveFinished events *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/igus-rebel)
* **LogicStep SetSignalFloat & WaitForSignalFloat** – Two new logic step components for float signal control in automation sequences. SetSignalFloat sets a float signal to a specified value (non-blocking), while WaitForSignalFloat waits until a float signal meets a configurable condition with 5 comparison operators (>, <, ==, >=, <=) and adjustable tolerance *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/defining-logic/logicsteps)
✨ **Enhancements**
* **Reparenting Tool** – Migrated from IMGUI to UI Toolkit with improved workflow. Selected GameObject is now automatically set as Object to Move, so users only need to pick the target parent. Matches the MovePivot tool pattern with overlay and dedicated window support *(Professional)*
* **PackageShare Email Integration** – Upload workflow now includes recipient email, name, and message fields directly in the upload form. Email delivery status is shown in the magic link dialog *(Professional)*
🐛 **Bug Fixes**
* **Drive DriveTo 360 Wrap-Around** – Fixed DriveTo operations being clamped at UpperLimit on rotational drives, preventing crossing the 360°→0° boundary. LogicStep\_DriveTo and all other DriveTo callers now correctly wrap around on rotational drives with JumpToLowerLimitOnUpperLimit enabled *(Professional & Starter)*
* **Denso Interface** – Unified real robot and VRC communication into a single bCAP client connection. Fixed broken ConnectRealRobot property with NotImplementedException stubs and corrected connection strings for both modes. I/O support now works for both real robot and VRC *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/denso-robotics-pro)
* **UI Dropdown Navigation** – Fixed camera navigation consuming arrow keys while uGUI Dropdowns are focused. SceneMouseNavigation now detects uGUI elements via RaycastAll and blocks camera input when pointer is over UI controls *(Professional & Starter)*
* **Source Spawn Collider** – Fixed collider state handling when spawning MUs from Source components *(Professional & Starter)*
* **KinematicTool Second Axis** – Fixed NullReferenceException when interacting with the second axis in the KinematicTool editor *(Professional)*
* **TransportSurface GroupName** – Fixed kinematic group name resolution by using GetGroupName() method instead of direct property access *(Professional & Starter)*
* **Siemens Simit Interface Startup** – Fixed double XML/XLS signal file write on interface startup in builds. Removed redundant signal initialization that caused duplicate file exports. Added clean reconnect state reset for reliable re-initialization after disconnects *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/siemens-simit-interface-pro)
**6.0.10-8590** — *15 February 2026* **Available for:** realvirtual **Starter** **Unity Support:** Unity 6000.0.28f1 and upwards (Unity 6) and Unity 2022 LTS
🚀 **New Features**
* **LogicStep SetSignalFloat & WaitForSignalFloat** – Two new logic step components for float signal control in automation sequences. SetSignalFloat sets a float signal to a specified value (non-blocking), while WaitForSignalFloat waits until a float signal meets a configurable condition with 5 comparison operators (>, <, ==, >=, <=) and adjustable tolerance *(Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/defining-logic/logicsteps)
🐛 **Bug Fixes**
* **Drive DriveTo 360 Wrap-Around** – Fixed DriveTo operations being clamped at UpperLimit on rotational drives, preventing crossing the 360°→0° boundary *(Starter)*
* **UI Dropdown Navigation** – Fixed camera navigation consuming arrow keys while uGUI Dropdowns are focused *(Starter)*
* **Source Spawn Collider** – Fixed collider state handling when spawning MUs from Source components *(Starter)*
* **TransportSurface GroupName** – Fixed kinematic group name resolution by using GetGroupName() method instead of direct property access *(Starter)*
**6.0.9-8533** — *4 February 2026* **Available for:** realvirtual **Professional** **Unity Support:** Unity 6000.0.28f1 and upwards (Unity 6) and Unity 2022 LTS
🚀 **New Features**
* **Chain Burst Compiler Optimization** – Added Unity Burst Compiler support for Chain component with automatic performance optimization up to 33x faster. Implements TransformAccessArray with IJobParallelForTransform for kinematic elements (29-33x speedup) and IJobParallelFor for physics elements (19-23x speedup). Features hybrid architecture that automatically splits elements based on MoveRigidBody flag, direct Burst transform writes for maximum performance, and intelligent spline baking with 100 cached samples. Includes one-click setup UI with NaughtyAttributes integration for automatic Burst package installation and REALVIRTUAL\_BURST compiler define configuration. Performance scales with element count - 100 kinematic elements: 5.8ms → 0.2ms (29x faster), 200 elements: 11.6ms → 0.35ms (33x faster) *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/chain)
* **Drive Position Switch** – New DriveBehavior component that controls a boolean PLC signal based on drive position ranges. Supports multiple position areas with OR logic, area inversion for defining exclusion zones, global position offset with automatic normalization, and full wrap-around support for rotational drives. Features automatic detection of wrapped areas (e.g., 350-10° on 0-360° drives) with position normalization that handles drives temporarily exceeding limits during wrapping *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/drive-position-switch)
* **LogicStep SetActiveOnly** – New logic step component that controls the ActiveOnly property of multiple realvirtualBehavior components simultaneously. Enables batch activation/deactivation of Drives, Sensors, and other components during automation sequences. Non-blocking step for instant execution within LogicSteps workflows *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/defining-logic/logicsteps)
✨ **Enhancements**
* **Source Collider State Preservation** – Source component now preserves the initial enabled/disabled state of all colliders in the template, including colliders on inactive child GameObjects. Generated MUs maintain the exact collider configuration from the template prefab, allowing users to control which colliders should be enabled or disabled on spawned objects. Fixes existing bug where colliders on inactive GameObjects were not properly handled. Also updated base SetCollider() method to include inactive GameObjects across all components *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/mu-movable-unit/source)
* **Drive Behavior Position Feedback Scale/Offset** – Added symmetric scale and offset transformations for position feedback in all drive behaviors with position feedback (Drive\_DestinationMotor, Drive\_ContinuousDestination, Drive\_FollowPosition, Drive\_Simple, Drive\_Speed, Drive\_MeasureSpeedPosition). Enables proper closed-loop control with PLCs by applying inverse transformation to feedback values. New properties: Current Position Scale, Current Position Offset, and Scale Feedback Position (boolean, default true) to optionally disable transformations and receive raw position values *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/drive-behavior)
* **Drive\_Cylinder Inverted Control Logic** – Added Invert Output Logic boolean property to Drive\_Cylinder for normally-closed valve configurations or inverted signal requirements. When enabled, Out=false extends the cylinder and Out=true retracts it, reversing the standard control logic *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/drive-behavior)
* **Runtime UI Tooltip System** – New tooltip components (rvUITooltip, rvUITooltipGenerator) for creating hover tooltips on UI elements with configurable delay, automatic placement, and style-aware positioning that adapts to window, vertical, and horizontal menu layouts *(Professional)*
🐛 **Bug Fixes**
* **Pre/Post FixedUpdate Performance** – Fixed performance issues with IPreFixedUpdate and IPostFixedUpdate interface implementations that were causing unnecessary overhead during physics simulation cycles *(Professional & Starter)*
* **Denso Interface Dynamic Axis Count** – Updated DensoInterface to support Denso robots with 4 or more axes instead of requiring exactly 6. Robot axis arrays are now dynamically allocated based on actual drive count, supporting configurations from 4 to 12 axes *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/denso-robotics)
**realvirtual.io Simulation 6.0.9-8533** — *4 February 2026* **Compatible with:** realvirtual 6.0.9 Professional and Starter **Unity Support:** Unity 6, Unity 2022 LTS, and Tuanjie (Chinese market)
✨ **Enhancements**
* **Unity 2022 LTS and Tuanjie Compatibility** – Full compatibility with Unity 2022 LTS and Tuanjie engine for the Chinese market, enabling conveyor system simulations across all supported Unity versions
**6.0.8-8217** — *7 November 2025* **Available for:** realvirtual **Professional** **Unity Support:** Unity 6000.0.28f1 and upwards (Unity 6)
🚀 **New Features**
* **Material Icons System** – Integration of Google Material Design Icons with 2234 icons available for both Editor and Runtime UI4
* **OpenCommissioning Interface Integration** – Added conditional assembly definitions for seamless integration with OpenCommissioning package (<https://github.com/OpenCommissioning/OC\\_Unity\\_Core>). Includes 7 link components (Cylinder, Drive Position, Drive Simple, Drive Speed, Grip, Lamp, Sensor) with custom UI Toolkit inspectors. Integration automatically activates when OpenCommissioning package is installed via Unity Package Manager *(Professional & Starter)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/opencommissioning)
✨ **Enhancements**
* **Component Menu Organization** – Added organized component menus for all major realvirtual components and interfaces. Components now accessible via `Component > Add` menu with logical categorization: Material Flow (Source, Sink, MU), Motion (Drive + 9 behaviors), Sensors, Gripping, Transport, Professional (IK, PathTracer), Visualization, and Interfaces. All 30+ interface classes now available under unified `realvirtual/Interfaces/` menu for improved discoverability *(Professional)*
* **EditorGizmoOptions Customization** – Centralized editor gizmo settings with 29 customizable properties for drive gizmos (colors, sizes, arrow clicking), move pivot tool, duplicate finder, material window, and kinematic tool. All gizmo colors and dimensions now configurable through Unity Inspector
* **Editor Toolbar System** – Enhanced overlay toolbar buttons with Material Icon integration and Unity's standard blue active state. Improved visual feedback for overlay visibility and cleaner toolbar integration
* **QuickEdit Interface Management** – New "Add Interface" button in QuickEdit overlay provides one-click access to all available communication interfaces. Automatically lists interfaces alphabetically with cleaned display names (Interface suffix removed), creates new scene roots when nothing is selected, or adds interface to existing empty scene roots. Streamlines workflow for setting up PLC, OPC-UA, Modbus, S7, and other industrial protocol connections *(Professional)*
* **UDP Interface CSV Import** – Added CSV symbol table import functionality for automatic signal configuration. Supports BOOL, INT, and REAL data types with automatic byte position calculation. Import signals directly from PLC or SCADA system exports with configurable delimiter support. Includes Inspector buttons for file selection and import with comprehensive validation and error handling *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/udp-pro#csv-symbol-table-import)
🐛 **Bug Fixes**
* **Mitsubishi MCP-X Interface CSV Import** – Fixed metadata not being populated on first Import button press. Signal manager now refreshes before metadata assignment, enabling proper single-operation import workflow *(Professional)*
* **S7 TCP/IP Interface** – Fixed critical buffer overflow issues, incomplete reads, and offset calculation errors. Implemented non-blocking connection mechanism to prevent Editor freezing when connecting to unreachable PLCs, with configurable ConnectionTimeout property (default 10 seconds)
* **Keba Interface** – Reliability improvements and bug fixes *(Professional)*
* **Toolbar Buttons** – Corrected active state display across all overlay toolbar buttons (Material Window, QuickEdit, RecentItems, Simulation)
**realvirtual.io Simulation 6.0.8-8217** — *7 November 2025* **Compatible with:** realvirtual 6.0.8 Professional
🚀 **New Features**
* **Simulation Overlay** – New Scene view overlay with toolbar integration for rapid conveyor system assembly. Provides one-click access to straight conveyors, curved conveyors, chain transfers, guide rolls, sources, sinks, and path components (lines and curves). Integrated with toolbar toggle button and Material Icon system for streamlined simulation workflow
🐛 **Bug Fixes**
* **Chain Transfer Component** – Fixed chain not lifting off conveyor despite showing 'Out' status. Resolved motion response issues and added collision detection for proper transfer functionality
* **Shoe Sorter Component** – Fixed shoes not starting at conveyor front position. Corrected shoe positioning behavior where shoes would march forward leaving the conveyor belt instead of staying synchronized with belt movement
**6.0.7-8152** — *26 October 2025* **Available for:** realvirtual **Professional\*\*\*\*Unity Support:** Unity 6000.0.28f1 (Unity 6)
🚀 **New Features**
* **PathTracer Component** – Visualize object movement paths with speed-based coloring and trail persistence, enabling motion analysis and optimization validation during simulation runs *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/path-tracer)
* **Duplicate Finder Tool** – Mesh-based duplicate detection with hash comparison for identifying identical geometries and optimizing scene performance through asset consolidation *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/tools/duplicate-finder)
* **Material Window Duplicate Detection** – Integrated duplicate finder in Material Window showing real-time duplicate count and scene analysis progress for selected objects *(Professional)*
* **Recent Items Tracker** – Editor toolbar overlay that tracks and provides quick access to recently selected scene objects, project assets, and scenes *(Professional)* - [Documentation](https://doc.realvirtual.io/basics/user-interface/recent-items-pro)
* **State Statistics Component** – Production state tracking with time-based statistics collection for OEE analysis, bottleneck identification, and performance monitoring *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/statistics/state-statistics)
* **Camera Follow Object** – Automated camera tracking component with smooth pursuit, configurable offset, and rotation following for cinematic views *(Professional)* - [Documentation](https://doc.realvirtual.io/basics/runtime-ui/camera-control)
✨ **Enhancements**
* **Industrial Interface Improvements** – Enhanced FastInterfaceBase, updated Mitsubishi McpX protocol support, and PLCSIMAdvanced interface refinements for industrial connectivity *(Professional)*
* **Runtime UI Enhancements** – New camera focus button component, improved scene mouse navigation, and inspector refinements *(Professional)*
🐛 **Bug Fixes**
* Fixed PLCSIMAdvanced interface connection stability *(Professional)*
**6.0.6-7994** — *3 October 2025***Available for:** realvirtual **Professional\*\*\*\*Unity Support:** Unity 6000.0.28f1 (Unity 6)
🚀 **New Features**
* **Enhanced FastInterface System** – Added IOnInterfaceEnable, IPreFixedUpdate, and IPostFixedUpdate interfaces for precise industrial interface timing control *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/custom-interfaces)
* **Blueprint FastInterface Template** – Complete reference implementation demonstrating signal discovery, metadata handling, thread-safe patterns, and value simulation for custom interface development *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/custom-interfaces)
✨ **Enhancements**
* **Siemens Simit Interface Rework** – Migrated to FastInterface standard with improved initialization sequence, proper signal coupling, and enhanced debugging capabilities *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/siemens-simit-interface-pro)
* **Camera Rotation Around Mouse Position** – Scene camera now rotates around mouse cursor position in Play mode for more intuitive navigation and inspection *(Professional & Starter)*
* **Interface Lifecycle Management** – FastInterfaceBase now follows realvirtual Controller initialization pattern with OnInterfaceEnable and IPostAllScenesLoaded for proper startup sequencing *(Professional)*
* **FastInterface Pre/Post FixedUpdate** – Signal synchronization moved to IPreFixedUpdate (PLC→Unity before physics) and IPostFixedUpdate (Unity→PLC after physics) for consistent timing *(Professional)*
🐛 **Bug Fixes**
* Fixed SceneSelectable UnityEvent callback for adding links to scene selectable content *(Professional)*
* Fixed Siemens Simit coupler initialization preventing proper signal connection in realvirtualCoupler *(Professional)*
* Resolved FastInterfaceBase signal synchronization timing issues by implementing Pre/Post FixedUpdate pattern *(Professional)*
**6.0.5-7962** — *28 September 2025***Available for:** realvirtual **Professional\*\*\*\*Unity Support:** Unity 6000.0.28f1 (Unity 6)
🚀 **New Features**
* **KeyboardMove Component** – Precise keyboard-controlled movement with smooth interpolation, axis limits, and customizable key bindings for interactive positioning *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/scene-interaction/keyboard-move)
* **EthernetIP libplctag 1.5.2** – Major update with comprehensive PLC mapper support including Bool, Dint, Int, Real, String, and Timer mappers for enhanced industrial connectivity *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/ethernetip)
* **Enhanced FixedUpdate Event System** – New IPreFixedUpdate and IPostFixedUpdate interfaces enabling precise timing control and improved component lifecycle management *(Professional)*
✨ **Enhancements**
* **UI Height Management System** – Significant improvements to rvUIHeightAdjuster and rvUIHeightContributor for dynamic UI layouts with constraints and real-time adjustment capabilities *(Professional)*
* **Scene Selection System** – Extended SceneSelectable with AddStringContent and AddLinkContent methods for dynamic content management *(Professional)*
* **Signal System Performance** – Optimized FastSignalManager, FastSignalManagerHelper, and FastInterfaceBase for reduced overhead and better real-time performance *(Professional)*
* **Thread-Safe Logging** – Enhanced ThreadSafeLogger implementation for improved performance in multi-threaded industrial interface scenarios *(Professional)*
🐛 **Bug Fixes**
* Fixed PLC signal integration issues in PLCInputBool, PLCInputFloat, PLCInputInt, PLCOutputBool, PLCOutputFloat, and PLCOutputInt components *(Professional)*
* Resolved networking stability problems in NetworkInitializer and XRMultiuserSetup for improved collaborative sessions *(Professional)*
* Corrected FastInterfaceBase performance bottlenecks affecting real-time signal processing *(Professional)*
* Fixed SwitchInputSystem handling for seamless VR/AR input mode transitions *(Professional)*
* Resolved realvirtualController initialization sequence issues affecting component startup *(Professional)*
* Fixed KEBA Interface connection handling and data exchange reliability for KEBA automation controllers *(Professional)*
**Migration Notes**
* The new IPreFixedUpdate/IPostFixedUpdate interfaces provide optional enhanced timing control - existing components continue to work without modification
* EthernetIP library upgrade to 1.5.2 maintains backward compatibility while adding new mapper capabilities
**Performance Improvements**
* Optimized signal update mechanisms with reduced allocation in FastSignalManager
* Improved thread synchronization in industrial interfaces reduces latency
* Enhanced UI height calculation system reduces layout computation overhead
**realvirtual.io Simulation 6.0.5-7962** — *28 September 2025***Compatible with:** realvirtual 6.0.5 Professional
* Fixed CurvedConveyor bug
**6.0.4-7894** — *16 September 2025***Available for:** realvirtual **Professional** and **Starter\*\*\*\*Unity Support:** Unity 6000.0.28f1 (Unity 6) and Unity 2022 LTS
🚀 **New Features**
* **Scene Selection System** – Interactive 3D object selection with multi-layer visual feedback, hover effects, and real-time signal manipulation *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/scene-interaction/scene-selectables-pro)
* **Advanced Rendering Features** – Multi-object outline and overlay rendering with global mesh control for performance optimization *(Professional)*
* **KEBA Interface** – Real-time bidirectional data exchange with KEBA automation controllers *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/keba-interface)
* **KUKA Interface** – TCP/IP communication with KUKA OfficeLite virtual controllers *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/kuka)
* **Mitsubishi MCPX Interface** – MC Protocol support for Q, L, R, iQ-R, and iQ-F series PLCs *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces/mitsubishi-mcpx)
* **Enhanced Testing Framework** – Automated MQTT signal testing and renderer feature safety validation *(Professional & Starter)*
✨ **Enhancements**
* **Centralized Logging System** – New Logger class with hierarchical path tracking and color-coded messages replacing Debug.Log throughout framework *(Professional & Starter)*
* **Comprehensive Documentation** – Added detailed doxygen documentation to major components including MU, TransportSurface, and scene selection system *(Professional & Starter)*
* **UI System Improvements** – Enhanced window positioning, scaling, and URL field handling with better canvas boundary detection *(Professional & Starter)*
* **Multiplayer Networking** – Improved NetworkSensor, NetworkDrive, and NetworkMU with better owner-based control and synchronization *(Professional)*
* **Industrial Interface Updates** – Enhanced MQTT, SEW, Siemens, and new Wandelbots NOVA interfaces with improved connection handling *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/interfaces)
* **Component Lifecycle Management** – Better signal tracking, transport surface documentation, and enhanced gripper functionality *(Professional & Starter)*
🐛 **Bug Fixes**
* Fixed physics synchronization issues during VR/AR object placement *(Professional)*
* Corrected window positioning problems at canvas boundaries *(Professional & Starter)*
* Improved network sensor value synchronization between owner and clients *(Professional)*
* Fixed passthrough enable/disable logic in XR applications *(Professional)*
* Resolved scaling calculations for UI windows in different screen configurations *(Professional & Starter)*
**Breaking Changes**
* Removed deprecated EnableXR component - use Unity XR Management instead
**Migration Notes**
* Logger class integration: Replace Debug.Log calls with Logger.Message() for consistent hierarchical logging
* XR features require Meta XR SDK 68.0 or later
* Multiplayer features require Unity Netcode for GameObjects 1.8.1 or later
* Optimized selection rendering with new multi-object render features
* Better physics simulation control during placement operations
* Enhanced signal update mechanisms for improved real-time performance
**realvirtual.io Industrial Metaverse 6.0.4-7894** — *16 September 2025***Compatible with:** realvirtual 6.0.4 Professional**Requires:** Meta XR SDK 68.0 or later
* Enhanced AR/VR scene integration with new XR placement system
* Improved passthrough functionality and depth occlusion controls
* Updated Imverse UI components for industrial metaverse applications
* Compatible with new multiuser XR support features
**realvirtual.io Simulation 6.0.4-7894** — *16 September 2025***Compatible with:** realvirtual 6.0.4 Professional and Starter
* Updated for full compatibility with 6.0.4 framework
* Enhanced conveyor system integration
* Improved performance with new rendering features
**realvirtual.io AIBuilder 6.0.4-7894** — *16 September 2025***Compatible with:** realvirtual 6.0.4 Professional and Starter
* Framework compatibility updates for 6.0.4 architecture
* Integration with new centralized logging system
* Enhanced signal testing framework compatibility
**6.0.3** — *18 August 2025*\
**Available for:** realvirtual **Starter**\
**Unity Support:** Unity 6000.0.28f1 (Unity 6) and Unity 2022 LTS (Tuanjie Version for Chinese market)
For complete feature details and Professional-only features, see the realvirtual Professional 6.0.3 release (13 August 2025) below.
**6.0.3** — *13 August 2025*\
**Available for:** realvirtual **Professional**\
🚀 **New Features**
* **MUSwitcher Component** – Dynamic MU variant visualization based on sensor detection *(Starter + Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/changing-mus/muswitcher)
* **Runtime Persistence System** – Save and restore UI settings (including mouse sensitivity) during play mode *(Starter + Professional)* - [Documentation](https://doc.realvirtual.io/basics/runtime-ui/runtime-persistence)
* **Professional Editor Tools Upgrade** – New design & extended features for **MovePivot**, **AxisAligner**, and **ReparentingTool** *(Professional)* - [MovePivot](https://doc.realvirtual.io/basics/user-interface/move-pivot-points-pro), [ReparentingTool](https://doc.realvirtual.io/basics/user-interface/reparenting-tool-pro)
* **QuickEdit System Redesign** – Modern UI Toolkit integration with improved MovePivot overlay *(Starter + Professional)* - [Documentation](https://doc.realvirtual.io/basics/user-interface/quick-edit)
* **realvirtual Overlay Toolbar** – New Scene view toolbar for quick access to framework tools *(Starter + Professional)*
* **Scene Validation Function** – Check references & component integrity *(Starter + Professional)*
* **LogicSteps Concept** – Parallel & serial containers with cycle time statistics and enhanced debugging *(Starter + Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/defining-logic/logicsteps)
✨ **Enhancements**
* **StatDisplay System** – Comprehensive real-time performance monitoring and production statistics for industrial automation analysis *(Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/scene-interaction/statdisplay)
* **TransportSurface Kinematic Group Support** – Enhanced collider handling with automatic kinematic group integration for improved CAD assembly performance *(Starter + Professional)* - [Documentation](https://doc.realvirtual.io/components-and-scripts/motion/transportsurface#collider-handling)
* Improved **Apply Standard Settings** & added **Project Path Display** in Unity's main toolbar *(Starter + Professional)*
* Expanded **Documentation** with full Doxygen standards across core components *(Starter + Professional)*
🐛 **Bug Fixes**
* Upgraded **Logger Class** with hierarchical logging capabilities *(Starter + Professional)*
* Fixed PLC control logic in demo scene *(Starter + Professional)*
* Fixed missing references and 3D components in demo scenes *(Starter + Professional)*
**Version 6.2.2 May 16, 2025 (realvirtual Starter)**
* Fixed Bug for SmoothDrive (wrong message in ConsoleLog)
**Version 6.2.1 06. May 2025 (realvirtual Professional, Starter, Simulation)**
* Bugfix Parent Drive
* Bugfix Transport Surface Animation
* Release realvirtual Simulation 6 (compatible with realvirtual Professional and Starter 6)
**Version 6.1.3 16. February 2025 (realvirtual Professional, Starter)**
* Minor visual improvements [Demo Scene](/basics/demo-model.md)
* Better responsiveness of RuntimeUI
* Integrated [RuntimeDebugger](/basics/runtime-ui/runtime-debugger.md) for Console Log messages in Build / Runtime
* Signal [JSON Exporter and Importer](/components-and-scripts/interfaces/signal-importer-exporter.md) for a neutral generic Signal Import and Export
* New [Scene Selectables](/components-and-scripts/scene-interaction/scene-selectables-pro.md)
* New [Runtime Persistance](/basics/runtime-ui/runtime-persistence.md) for saving properties which are changed in Build / Runtime
* Fixed nearly all Warnings in console log
**Version 6.1.2 28. January 2025 (realvirtual Professional)**
* Improvements Demo Scene
* Bugfix Wandelbots NOVA Interface
* Improvements on Icons and Buttons on smaller Devices and WebGL
**Version 6.1.1 23. January 2025 (realvirtual Professional)**
* Fixed Bug in CADLink with automatically adding Colliders and creating Instantiated Materials
**Version 6.1.0 21. January 2024 (realvirtual Professional, Starter)**
* New Demo Scene
* [New Overlay Buttons](/components-and-scripts/scene-interaction/screen-overlay-buttons.md)
* [New 3D Scene Buttons](/components-and-scripts/scene-interaction/3d-buttons.md)
* New [Volume Tracking](/components-and-scripts/volume-tracking-pro.md)
**Version 6.0.1 23. November 2024 (realvirtual Professional, Starter)**
* New Signal in Source for generation based on Distance
* Fixed Bug Ortho Overlay windows in Play mode
* Fixed Bug in TransportSurface when DriveParent is used an moving
**Version 6.0.0 6. November 2024 (realvirtual Professional, Starter)**
* Release based on Unity 6
* Please check the [Upgrade](/advanced-topics/upgrade-guide.md) guide for upgrading old projects
* New Igus Rebel Interface
* New URP Pipeline settings, Light, Bottom and Environment Settings - see [EnvironmentController](/components-and-scripts/game4automation/environment-controller.md)
* New [Visual Scripting](/components-and-scripts/defining-logic/behavior-graph.md) based on [Behavior Graph](/components-and-scripts/defining-logic/behavior-graph.md)
**Version 2022.18 18. September 2024 (realvirtual Professional & Simulation)**
* Bugfix Selection Window
* Bugfix Duplicated Name in Signal
* Bugfix TwinCAT interface with new BestHTTP3 library
* Bugfix missing attribute LastCameraPosition in SceneMouseNavigation
* Bugfix Measure Tool for Radius
* Selection Window Prefix of Groups is now also used in Group Filter
* Bugfix QuickEdit for Pathes (Curves and Lines) (only realvirtual Simulation)
**Version 2022.17 16. August 2024 (realvirtual Professional & Starter)**
\*\*If you are upgrading to 2022.17 from versions before please delete before importing the new release these files:\*\*
* **realvirtual/Professional/CollectionBuilder/PlannerAttribute.cs**
* **andy maybe, if existing somewhere in your project the file "EnvironmentSetup.cs"**
* **New SEW MQTT Interface:** Introduced a new interface for SEW MQTT, enhancing communication capabilities with SEW Controllers (only Professional)
* **Improvements in FixedUpdate Sequence:** Enhanced the FixedUpdate sequence for better performance and predictability. New events in the Drive component have been added (details at [motion-for-developers](https://doc.realvirtual.io/components-and-scripts/motion/motion-for-developers)).
* **Improved Folder Structure:** All Professional functions, except for interfaces, are now organized under the realvirtual Professional directory, improving project organization.
* **Improvements and Bug Fixing in Kinematic Tool:** Enhanced functionality and resolved issues in the Kinematic Tool for more reliable operation (only Professional).
* **Bug Fix - Linux Compilation:** Addressed and fixed compilation issues specific to Linux.
* **Bug Fix Render Pipeline switching** - see <https://doc.realvirtual.io/advanced-topics/render-pipelines>
**Version 2022.16 31. July 2024 (realvirtual Professional & Simulation)**
* Bugfix CAM on continous CAMs with offsets.
* Bugfix for new feature GuidedTransport on TransportSurfaces in realvirtual Simulation
* Bugfix Snapping in combination with realvirtual Simulation
* Bugfix Simulation Pause in combination with realvirtual Simulation
* Bugfix Sensor on CurvedConveyor in realvirtual Simulation
**Version 2022.15 15. July 2024 (realvirtual Professional)**
{% hint style="warning" %}
Before upgrading from an old release 2022.14 and before please imort into the existing project this Unitypackage below. After this you are ready to install the main update to 2022.15
{% file src="/files/r2N15EE0XywDl6k9ENhl" %}
* Added Testing (<https://doc.realvirtual.io/advanced-topics/for-developers/testing>)
* Bugfixes Kinematic Tool (<https://doc.realvirtual.io/basics/user-interface/kinematic-tool>)
* Bugfix on FixedUpdate sequence on Gears (see (<https://forum.realvirtual.io/communities/1/topics/653-adding-kinematics-on-pendulum-like-object>)
* Bugfix on SceneMouse Navigation and Selection, added again icons for selecting views in Demo scene.
**Version 2022.14 04. July 2024 (realvirtual Professional)**
* Added warning on CAD import for non instantiated (into Assets folder) meshes.
* Added Model Checker for giving hints on possible problems (see <https://doc.realvirtual.io/basics/user-interface/model-checker>).
* Added Kinematic Tool for faster kinematic definition (see <https://doc.realvirtual.io/basics/user-interface/kinematic-tool>)
* Fixed problem compiling Inverse Kinematics to some mobile platforms.
* Fixed problem with Fixer in some circumstances.
* Fixed problem with FixedUpdate sequence of Drives, CAMs, Gears and Behavior models (see <https://doc.realvirtual.io/components-and-scripts/motion/drive-behavior>)
* Extended example model for loading and unloading MUs (see <https://doc.realvirtual.io/components-and-scripts/mu-movable-unit>).
**Version 2022.13 17. Mai 2024 (realvirtual Professional, Simulation)**
* Added RFSuide interface (<https://doc.realvirtual.io/components-and-scripts/interfaces/rfsuite>)
* Added Winmod interface (<https://doc.realvirtual.io/components-and-scripts/interfaces/windmod-y200>)
* Added UDP interface (<https://doc.realvirtual.io/components-and-scripts/interfaces/udp>)
* Added Websocket interface (<https://doc.realvirtual.io/components-and-scripts/interfaces/websocket>)
* Fixed severe bug inverse kinematics. Added Autonox robots, Autonox performance test model and empty kinematic (<https://doc.realvirtual.io/components-and-scripts/robot-inverse-kinematics>)
* Added Pick and Place function to Robot Inverse Kinematic Pathpoints
* Much better mouse navigation in Build (prevented deadlocks, hangs and so on)
* Bugfix vertical chain (<https://doc.realvirtual.io/components-and-scripts/motion/chain>)
* Displaying Groupname Prefix in Hierarchy View
* Smooth interpolation between different saved Camera Positions
* Fixed bug on radial conveyor sensor (realvirtual.io Simulation)
* Fixed bug on guide rolls (realvirtual Simulation) (<https://game4automation.userecho.com/helpdesks/3/tickets/635-mus-changing-direction>).
**Version 2022.12 29. Apri 2024 (realvirtual Professional)**
* Bugfix URRobots Interface
* Added compatibility to AR, XR scaling for realvirtual.io Industrial Metaverse
* Enhanced URP and HDRP switching
* Bugfix for OPCUA when connectiong to S7 OPCUA servers
* New Drive public method SetPosition(float position) for prevent one fixed update delay of positions for CAMs, FollowPosition and DriveRecordings.
**Version 2022.11 13. March 2024 (realvirtual Professional)**
* Switching between render pipelines with the main menu (see <https://doc.realvirtual.io/advanced-topics/render-pipelines#switching-render-pipelines>)
* Upgrade of TwinCATHMI interface and MQTT interface to BestHTTPV3 and BestMQTTV3 support.
* New Pivot tool (see h[ttps://doc.realvirtual.io/basics/user-interface/move-pivot-points](https://doc.realvirtual.io/basics/user-interface/move-pivot-points).)
* New Cutter function for cutting MUs into pieces (see <https://doc.realvirtual.io/components-and-scripts/cutter>)
* Support of MQTT interface value parse for international floats and 0/1 to bool conversion.
* Support in CAM for importing excel files.
* Bugfix Mesh Gizmo in Kinematic
* Bugfix Measure Tool.
**Version 2022.10 10. Februar 2024 (realvirtual Professional, Simulation, OPCUA4Unity)**
* Bugfix OPCUA Interface when reconnecting or using some IP adresses
* New measure tool (see <https://doc.realvirtual.io/basics/measurement>)
* Bugfix GuidedTransport in circular collider and demo model
* Bugfix compling and running on MacOs (complier defines adopted)
* Bugfix snapping and side guides in realvirtual Simulation
**Version 2022.09 11. November 2023 (realvirtual Professional)**
* New interface to virtual Denso robot controllers Wincaps III (see <https://doc.realvirtual.io/components-and-scripts/interfaces/denso-robotics>)
**Version 2022.08 27. September 2023 (realvirtual Professional)**
* Bugfix Android Build
* FMU interface removed from release
* Bugfix HMI on Touch Displays
* Bugfix CADLink Step CAD interface
**Version 2022.07 07. September 2023 (realvirtual Professional)**
Bugfix scene mouse and touch panning if behinder bottom surface center.
Bugfix and improvements HMI ([see https://doc.realvirtual.io/components-and-scripts/hmi-components/start-your-own-hmi](https://doc.realvirtual.io/components-and-scripts/hmi-components/start-your-own-hmi)) (only Prof).
Linux compatible compiler defines.
**Version 2022.06 14. August 2023 (realvirtual Professional, Starter)**
Bugfix for some special CAD data proplems in CADLink Step interface (only Prof).
Bugfix normal maps and vertices for 3MF Import in CADLink (only Prof).
Bugfix scene mouse and touch panning if behinder bottom surface center (Prof and Starter).Bugfix and improvements HMI ([see https://doc.realvirtual.io/components-and-scripts/hmi-components/start-your-own-hmi](https://doc.realvirtual.io/components-and-scripts/hmi-components/start-your-own-hmi)) (only Prof).
**Version 2022.05 07. August 2023 (realvirtual Professional)**
Bugfix in Assembly definitions of some interfaces, which made some interfaces not work in editor.
**Version 2022.04 02. August 2023 (realvirtual Professional)**
New HMI components - see [https://doc.realvirtual.io/components-and-scripts/hmi-components](https://doc.realvirtual.io/components-and-scripts/motion/guided-transport)
**Version 2022.02 17. July 2023 (realvirtual Professional)**
PLCSimAdvanced interface now able to import "non HMI" PLC tags as well as structs.
Bugfix Siemens Simit Interface.
**Version 2022.01 30. June 2023 (realvirtual Professional, Starter)**
This is the first release for Unity 2022 LTS.
Compiles now also on WebGL without manually deleting
erything rebranded from old game4automation to new realvirtual
removed old and unnecessary things from main menu
please also check the upgrade guide from 2021 here: <https://doc.realvirtual.io/advanced-topics/upgrade-to-2022>
**Version 2021.17 19. June 2023 (realvirtual Professional)**
OPCUA new option for defining the Poll update rate (see <https://doc.realvirtual.io/components-and-scripts/interfaces/opcua#polling-opcu-nodes>).
New function for optimizing meshes (reducing the number of polygons after import):\
<https://doc.realvirtual.io/components-and-scripts/mesh-optimizer>.
Mouse and Touch navigation in Game mode improved, now working on all platforms including WebGL.
Bugfix PLCSim Advanced when working with Int.
Bogfix TwinCAT HMI interface when working with user logins.
Bugfix RobotIK target.
**Version 2021.16 31. March 2023 (realvirtual Simulation)**
Removed severe Bug in Snapping function between Conveyors.
Changes only made to realvirtual Simulation - noch changes in Starter or Professional)
**Version 2021.16 10. March 2023 (realvirtual Professional, CADLink)**
CADLink is now able to instantiate imported materials so that they are available in the Assets folder and not only in the scene / mesh itself.
Fixed Bugs in Performance Optimizer (rotation and undo)
Bugfixing Fixer - removed release on collission non MU option (will be replaced by Glue component in the next release)
Replay and restart option in Game4automationController (enables automatically restarting the scene for demonstration purposes)
**Version 2021.15 03. March 2023 (realvirtual Professional, Starter, OPCUA)**
New MaterialWindow for quickly assigning Materials to imported CAD data (<https://doc.realvirtual.io/basics/material-window>)
Solved Problems when connecting to some OPCUA servers (e.g. Matrikon).
Added Security Policy Selection and Password Signature Algorithm Selection for OPCUA Interface.
Improvements for PerformanceOptimizer.
Fixed problem with touch navigation and inverted axis in game mode.
**Version 2021.14 16. Februar 2023 (realvirtual Professional, realvirtual Simulation)**
OPCUA - added support for pathes below IP Adress.
Renamed Recording to DrivesRecording
New function Performance optimizer for baking meshes and improving performance in very large models: <https://doc.realvirtual.io/components-and-scripts/performance-optimizer>
Removed bug with layer settings in combination with realvirtual simulation
Added new interface based on Siemens Simit Interface: <https://doc.realvirtual.io/components-and-scripts/interfaces/siemens-simit-interface>
Selection raycast deactivated in standard game4automation prefab for preventing performance impacts when creating complex MU with sources.
**Version 2021.13 25. Januar 2023 (realvirtual Professional)**
Improved accuracy in RobotIK by calculating correction values.
Bugfix TransportSurface animation.
**Version 2021.12 13. Januar 2023 (realvirtual Professional , Starter, CADLink,OPCUA4Unity)**
Improved performance and bugfix Step Import in CADLink (Professional, CADLink).
OPCUA supported datatypes for realvirtual, conversion to PLCOutputInt (Uint16,Int16,UInt23,Int32) (Professional, OPCUA4Unity)
OPCUA bugfix reading null values on bad status of a node (Professional, OPCUA4Unity).
Bugfix TransportSurface animation (Professional, Starter)
Bugfix TwinCATHMI interface (Professional)
Inverse kinematic for Robots (RobotIK) - added function "Turn Correction" of 180 Degrees if sum of Axis 4 and 6 is 360, Axis 4 and 6 can be corrected by 180 Degrees.
**Version 2021.11 20. December 2022 (realvirtual Professional , Starter, CADLink)**
﻿Fixed problems with Speed Changes and [TransportSurface](https://publisher.unity.com/components-and-scripts/motion/transportsurface) animation.
Fixed performance and other issues with [CADLink](https://doc.realvirtual.io/basics/cad-import/cadlink) Step interface.
Changed properties in [TransportSurface](https://publisher.unity.com/components-and-scripts/motion/transportsurface) for limiting the RigidBody Constraints on enter and exit.
New export full project as zip file option in main menu bar.
Fixed Bug in [Drive](https://doc.realvirtual.io/components-and-scripts/motion/drive) with UpperLimit signal.
Fixed problem in Solutions within [RobotIK](https://doc.realvirtual.io/components-and-scripts/motion/robot-inverse-kinematics) and additional function for drive position correction on PTP movements.
**Version 2021.10 15. November 2022 (realvirtual Professional , Starter)**
New documentation pages (this pages).
Fixed problem in [Chain](/components-and-scripts/motion/chain.md) systems.
Fixed problems with [TransportSurfaces](/components-and-scripts/motion/transportsurface.md) and parent drives
[TransportSurface](/components-and-scripts/motion/transportsurface.md) Performance Optimization by only setting colliders in needed cases
Fixed the Problem with two NewtonSoftJSON DLLs (if it is twice in the project because of Unity packages) - see [Newtonsoft JSON](/advanced-topics/newtonsoft-json.md)
**Version 2021.09 01. November 2022 (realvirtual Professional , Starter)**
Orthographic overlay cameras for top, front and sideview ([https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions).](https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions).%5C).%3Cbr%3ESwitch)Switch]\([https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions%5C).%3Cbr%3ESwitch)Switch](https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions%5C).%3Cbr%3ESwitch)Switch)) for setting Main camera in orthographic mode ([https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions).](https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions).%5C).%3Cbr%3EGame)Game]\([https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions%5C).%3Cbr%3EGame)Game](https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions%5C).%3Cbr%3EGame)Game)) window camera position and view setting is saved automatically after game ends and restored.\
New design of standard scene and demo scene with black background and bottom.\
New Universal Robots interface including demo model with UR script example ([https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions).](https://realvirtual.io/documentation/current/runtimeui.html#Campera-Positions).%3Cbr%3EBug)
Bug in TransportSurface in combination with parent drives of version 2021.07 and 2021.08 fixed. Parent drive can now have multiple Drives above and movement direction of parent drive is not limited.
**Version 2021.08 26. Oktober 2022 (realvirtual Professional )**
Removed bug in Transportsurface with Parent Drives of Version 2021.07
**Version 2021.07 22. Oktober 2022 (realvirtual Professional, CADLink)**
Stability improvements in OPCUA interface.
Stability improvements in PLCSIM Advanced interface.
New MQTT interface ([https://realvirtual.io/documentation/current/mqtt.html).](https://realvirtual.io/documentation/current/mqtt.html).New)
New TwinCATHMI interface (<https://realvirtual.io/documentation/current/twincathmi.html>)
CAD Step import DLLs based on a new framework.
**Version 2021.06 26. Steptember 2022 (realvirtual Professional)**
Enhancements **Fixer** (blocking handing over to other fixers, limitation on tags and setting tags after fixing).
**Pattern** component for automatically building circular or matrix patterns with gameobjects (e.g. Fixer patterns).
New component Unfixer.
Support of additive scene loading, changes in **Game4automationController** for defining **additive scenes** for one scene. game4automation controller in additive scenes is automatically disabled.
**Version 2021.05 - 31. August 2022 (realvirtual Professional)**
Bugfix robot inverse kinematics when PTP and same position.
Bugfix DrivePosition in some rare cases with RobotIK.
Additional signal waiting and signal setting function on inverse kinematics targets.Added optional HomePosition for RobotIK on simulation start.
Bugfix inverted Upper and LowerLimit Signals on Drive.
Bugfix compile switches for SpaceNavigator and IOS.Improvements and bugfixes in Fixer for beeing able to act as a simple Gripper like vaccum grippers.
**Version 2021.04 - 26. August 2022 (realvirtual Professional)**
New robot inverse kinematic function (see <https://realvirtual.io/documentation/current/robotik.html>).
Temlate for creating new game4automation scenes with File > NewScene.\
Source is now working with Fixer on created Mus.
**Version 2021.03 - 14. Juli 2022 (realvirtual Professional, realvirtual Simulation)**
First 2021 release for Professinal AND Simulation. Minor changes in chain in Professional for compatiblity to Simulation.
In Simulation added Shoe Sorter, Cross Belt Sorter and Spiral Conveyor - see <https://realvirtual.io/documentation/current/conveyorlibrary.html>)
**Version 2021.02 - 07. Juli 2022 (realvirtual Professional, Starter)**
Support for AGX physics engine - see <https://realvirtual.io/documentation/current/agxphysics.html>
CreateOnDistance in source with optional random behavior - see <https://realvirtual.io/documentation/current/source.html>
Singal Manager able to deactivate unconnected signals - <https://realvirtual.io/documentation/current/signalmanager.html>
**Version 2021.01 -24. June 2022 (realvirtual Professional, Starter)**
Product rebranded to realvirtual (namespace is unchanged for backwards compatibility)
Bugfixes OPCUA interface
Support for Unity Visual Scriping (see <https://realvirtual.io/documentation/current/unityvisualscripting.html>)
**Version 2020.15 -10. February 2022 (Game4Automation Professional)**
EthernetIP Interface added (see <https://game4automation.com/documentation/current/ethernetip.html>)
**Version 2020.14- 17 Januar 2022 (Game4Automation Professional)**\
OCUA basis framework changed to LibUA for compatiblity to IL2CPP, Hololens and IOS
**Version 2020.13- 08 December 2021 (Game4Automation Starter, Professional)**
New LogicSteps for visual scripting (Professional) (see <https://game4automation.com/documentation/current/logicsteps.html>).
Better performance and extensions MemoryArea ReadWrite Mode S7 interface (see <https://game4automation.com/documentation/current/s7tcpip.html>).
Additional CyclcSumCommand mode for faster communication with TwinCAT ADS (Professional) (see <https://game4automation.com/documentation/current/twincat.html>).
Added PerformanceOptimizer for combining meshes (Professional).
Added SignalManager for automatically connecting and creating signals (Professional).
**Version 2020.12- 21 November 2021 (Game4Automation Starter, Professional, Simulation)**
Bugfix S7Interface AreaReadWrite Mode
Bugfix compile errors for executables.
**Version 2020.11- 15 November 2021 (Game4Automation Starter, Professional, Simulation)**
Rebranding of Conveyor Library to Game4Automation Simulation
Changes in Starter and Professional for Game4Automation Simulation compatibility
**Version 2020.10 - 11 November2021 (Game4Automation Starter)**
Simit SHM now included in Starter
Bugfix QuickEdit Overlay
**Version 2020.09 - 13 October 2021 (Game4Automation Professional, Starter)**
New ABB RobotStudio Interface (only Professional)
Fixed bug in writing M floats in S7 interface
Interact3D component for Pushbuttons in 3D scene
Added support of Articulation Bodies kinematic
**Version 2020.08 - 17 September 2021 (Game4Automation Professional, Starter)**
New optional area read/write mode for faster signal exchange in S7 interface
Setting for display quality in runtime ui
Fixed bug missing hierarchy icons
**Version 2020.06 - 20 July 2021 (Game4Automation Professional, Starter)**
Added icons for standard game4automation scripts
![](https://forum.realvirtual.io/s/attachments/27424/2/1/13ba88a9308d4e881b01f8f5202cf412.png)
Better standard settings in source, sensor and mu
PLCOuput in Sensor now included - no Sensor\_Standard needed any more
Fixed compile error for Global.cs in Build
**Version 2020.05 - 09 July 2021 (Game4Automation Professional, Starter)**
New Force Drive - moving Cylinders with Forces
New Recorder for recording Drive movements (e.g. from external Robot Controller
Bugfixes QuickEdit
Bugfixes Gripper & Aligner
**Version 2020.04 - 29 June 2021 (Game4Automation Professional, Starter)**
Fixed Align for QuickEdit\
QuickEdit on/off is now saved in preferences\
New Fixer Component\
New example Model for Gripping objects (Grip, Gripper and Fixer)\
Restructured Code for Gripping (IFIX interface)
**Version 2020.03 - 22 June 2021 (Game4Automation Professional, Starter)**\
New Quick Edit Window for faster engineering workflow (see <https://game4automation.com/documentation/current/userinterface.html#Quickedit>)
Fixed problem with importing OPCUA nodes
Renaming Simulink interface
Fixed problem with reading boolean values from DBs in S7 interface
Calculate max distance in SceneMouseNavigation by bounding box
New script for modelling robot grippers with finger (Gripper.cs)
**Version 2020.02 - 14 May 2021 (Game4Automation Professional, Starter,OPCUA4Unity)**\
Fixed Bug in OPCUA with multiple parallel connections
Highlighting of Groups and Kinematic connections
Added ability to Grip part from another Gripper (see dermo
Assets/game4automation/Scenes/DemoGripping.unity)\
Added script for definiing drive motion sequences (see also Assets/game4automation/Scenes/DemoGripping.unity)\
Automatic calculation of maximimum scene mouse zoom in game mode based on bounding box\
Renaming of Matlab interface to Simulink interface\
Fixed positioning bug on rotating transport surfaces
**Version 2020.01 - 04. April 2021 (Game4Automation Professional, Starter,Conveyor-Library)**
Upgrade to Unity Version 2020 LTS
NaughtyAttributes upgraded, now remains in standard namespace
Improvements in Signal connection information
Improvements in Reconnect of OPCUA on connection losses
**Version 2019.13 - 31. March2021 (Game4Automation Professional, Starter)**
Minor changes for the new Game4Automation Conveyor Library
Compatibility with the Game4Automation Conveyor Library - available soon on the Unity Asset Store (see <https://game4automation.com/documentation/current/conveyorlibrary.html>)
**Version 2019.12 - 16. February 2021 (Game4Automation Professional, Starter, CADLink & OPCUA)**
Added ability to import Step files (CADLink)
Added Behavior Models for Drives - Drive\_Speed and Drive\_ContinousDestination (see <https://game4automation.com/documentation/current/drivebehaviour.html>)
Added Measure Component (see <https://game4automation.com/documentation/current/measure.html>)
Added MeasureRaycast Component (see <https://game4automation.com/documentation/current/measureraycast.html>)
Added FMI Interface (see <https://game4automation.com/documentation/current/fmu.html>, only Professional)
Added Events, Multithreaded Connection to OPCUA Interface (see <https://game4automation.com/documentation/current/opcua.html>, only OPCUA and Professional)
Added ability to delete MUs in Sensors
Added events to MUs (Load and Unload)
Added functions for correctly aligning ChainElements
Updated NaughtAttributes Tool to newest version
OPCUA now limited to Windows (IL2CPP and Mono) and Android (only Mono)
**Version 2019.11 - 29. November 2020 (Game4Automation Professional & Starter)**
Bugfix Gripper on robot in demo model.
**Version 2019.10 - 26. November 2020 (Game4Automation Professional & Starter)**
Added ability to hide non G4A components on GameObjects in Unity Editor\
Improved possibilities to move Transportsurfacs (see <https://forum.game4automation.com/de/communities/1/topics/188-colider-box-vertical-movment-on-chan-element>)\
New component StartDriveOnCondition (see Demo scene DemoStartDriveOnCondition)
**Version 2019.08 - 18. November 2020 (Game4Automation Professional)**
Bugfix OPCUA, fixing Licensing issues and IL2CPP compilation
**Version 2019.08 - 09. November 2020 (Game4Automation Professional)**
Fixed Bug OPCUA interface - missing references
**Version 2019.06 - 05. November 2020 (Game4Automation Professional)**
Fixed licensing issue for STEP interface
**Version 2019.05 - 23. October 2020 (Game4Automation Professional)**
CADLink - Added STEP Interface (see [**https://youtu.be/nsPeRgbU\_XE**](https://youtu.be/nsPeRgbU_XE))
S7 Interface - Added ability to read DB values (see <https://game4automation.com/documentation/current/s7tcpip.html#Reading-and-Writing-DBs>)
Modbus Interface Added (see <https://game4automation.com/documentation/current/modbus.html>)
**Version 2019.04 - 20. August 2020 (Game4Automation Professional, CADLink)**
CADLink 3mf export now supports big meshes with more than 65.000 vertices
CAM continuous function for driving e.g. chains with CAMS
CAMTime can be started at the end of another CAMTime
**Version 2019.03 - 12. August 2020 (Game4Automation Professional, Starter, OPCUA)**
**New Version numbering now with Unity Base Version (2019) in front of our Version number.**
**Please upgrade to Unity 2019.4 LTS!**
Better stability and automatic reconnecting for all interfaces (Shared Memory, OPCUA, TwinCAT, Sz-TCPIP)
Integrated First Person View in Runtime UI (<https://game4automation.com/documentation/current/runtimeui.html#Scene-Navigation>)
New standard switch to enable or disable components and for switch between Simulation Mode and Virtual Commissioning mode (<https://game4automation.com/documentation/current/runtimeui.html#Connection-Status>)
**Version 2019.01 - 07. July 2020 (Game4Automation Professional, Starter)**\
New RoboDK Interface ([**https://youtu.be/C2ZngS9Lhck**](https://youtu.be/C2ZngS9Lhck))
OPCUA bugfixes improvement
New ABB Robotstudio OPCUA Demo scene ([**https://youtu.be/3v8-7ap\_\_RA**](https://youtu.be/3v8-7ap__RA))
Chain Systems
**Version 1.036 - 07. June 2020 (Game4Automation Professional, Standard, CADLink)**
Bugfix CADLink import (recalculated Mesh Bounds)
New Function for PIXYZ based Update of large CAD Data (see [**https://youtu.be/1IC12iZzL0w**](https://youtu.be/1IC12iZzL0w))
PartChanger for changing visual appearance of CAD files (see <https://game4automation.com/documentation/current/partchanger.html>)
Bugfixes PLCSIMAdvanced Interface
Bugfixes Sensor and Grip
New function Prefixes in Groups
**Version 1.034 - 14. February 2020 (Game4Automation Professional & Starter)**
New function for motion axis CAM - see <https://game4automation.com/documentation/current/cam.html>, and on Youtube <https://youtu.be/nPNgIWcwDAM>
New tool for checking CAD imported meshes CADChecker (only Professional) - see <https://game4automation.com/documentation/current/cadchecker.html>
New tool for selecting and grouping components SelectionWindow (only Professional) - see <https://game4automation.com/documentation/current/selectionwindow.html>
**Version 1.033 - 08. January 2020 (Game4Automation Professional \&Starter)**
Bugfix Follow Parent option in Transportsurfaces
Removed Interact message on simulation startup
**Please remove Assetsgame4automationprivateEditorQuickToggle folder when upgrading from Version 1.031 and below!**
![](https://forum.realvirtual.io/s/attachments/27424/2/1/2865dc19ed4199a7d0be3a7693522a68.png)
**Version 1.032 - 18. December 2019 (Game4Automation Professional & Starter)**
Bugfix TwinCAT Interface (crash when starting multiple times)
Bugfix Interact when importing
**Version 1.031 - 17. December 2019 (Game4Automation Professional & Starter)**
New Icons in HierarchyView and HierarchyView Performance Improvement
![](https://forum.realvirtual.io/s/attachments/27424/2/1/7b5538c30cdfde9e3a7857ddef1e19da.png)
Performance Improvement Transportsurfaces
New Kinematic and Group Functions
(see Documentation <https://game4automation.com/documentation/current/kinematics.html>, and Youtube Tutorial: <https://youtu.be/c3Y6i7QyrxI>)
Interact Integration (Interact is an optional module for Game4Automation)
see <https://youtu.be/BQ3lLGU5l7c>
**Version 1.030 - 22. November 2019 (Game4Automation Professional & Starter)**
Added new radial Transportsurfaces. Transportsurface is getting radial as soon as you select RotationX,RotationY or RotationZ as direction. The center point of the rotation needs to be in the local coordinate system zero.
![](https://forum.realvirtual.io/s/attachments/27424/2/1/212e2d0542ddc0a29011acc1eb5f9d1b.png)
Changed calculated deltatime in Drives and Transportsurfaces to fixedtimeDelta for better accuracy.
**Version 1.029 - 19. November 2019**
Signals are now displaying if they are connected to a behavior model or not. If not, the signal values are displayed like that: "(SignalValue)"
![](https://forum.realvirtual.io/s/attachments/27424/2/1/d5a0e9b08e5ae6f494f6b2a0da6619ac.png)
Each Signal now has information about its connections to behavior models. In the section "Signal Connection Info" the Behavior model and the connection is displayed to which the signal is connected:
![](https://forum.realvirtual.io/s/attachments/27424/2/1/e1b01b0798f34827ca6e9314f65a998f.png)
**Version 1.028 - 15. November 2019 - Bugfix TwinCAT Interface**
Bugfix Error Drive directions and Drive handles in rotated assemblies
**Version 1.027 - 14. November 2019 - Bugfix winCAT Interface**
Bugfix read of signals (sometimes not all signals where transfered in one cycle together)
**Version 1.026 - 5. November 2019 - Bugfixes**
Bugfix in TwinCAT ADS typecasts\
Bugfix in OPCUA typecasts\
Better OPCUA4Unity and Game4Automation integration
**Version 1.025 - 31. October 2019 - TwinCAT**\
Beckhoff TwinCAT Interface integrated - see in Youtube
Drive Positions are now also working correctly if parent GameObjects are scaled. Position are always relative in millimeters, no matter how the scaling of the GameObject itself is.
**Version 1.024 - 25. October 2019 - Bugfixes**
Problem with space in path name for parts4cad fixed (<https://forum.game4automation.com/communities/1/topics/91-parts4cad-dont-open>)
Problem with rotational drive in combination with prismatic fixed (<https://forum.game4automation.com/communities/1/topics/109-problem-with-rotational-drive-in-combination-with-prismatic-drive>)
Full application, including OPCUA, now compiles again with .Net4.0 settings and Mono or ILCPP:
![](https://forum.realvirtual.io/s/attachments/27424/2/1/8f24e5bbf1976b439b1f003cba613504.png)
**You can find older release notes here:**
<https://game4automation.com/documentation/current/releasenotes.html>
GET https://doc.realvirtual.io/release-notes.md?ask=<question>&goal=<user_goal>
