> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-message.md).
# HMI Message (Deprecated)
realvirtual.io Professional
{% hint style="danger" %}
**Deprecated — replaced in realvirtual WEB.** This Unity uGUI message runtime is deprecated and is **not read by realvirtual WEB**. In the browser, signal-driven alarms and messages are provided by the **WebError** and **WebDiagnostics** components (feeding the WEB message/alarm panel), and step-by-step operator instructions by **CustomRuntimeInstruction** (with per-step 3D highlighting and isolate-on-click). See [**realvirtual WEB**](/extensions/realvirtual-web.md). Use those components instead of `HMI Message` for new work.
HMI Messages can be used to display for example warnings, failures or maintenance information based on the PLC Status. Each HMI Message is activated by a PLCOutputBool.
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-7bc1396f6a2325d49fb95b850f9e3d94e7b1b127%2FhmiMsgExmp.gif?alt=media" alt=""><figcaption></figcaption></figure>
Messages are sorted into the message stack by category (Failure, Warning, Message) and based on the time stamps. Messages can be modal (they ned to be Acknowledged before any other Message can be displayed) or not. If Messages are not modal they can be closed without acknowledgement. They are sorted to the last position on the message stack.
To provide messages consists of 3 areas
1. on the left: message icon
2. in the middle: message text and the time stamp
3. on the right: message buttons:
   1. show/ information button
   2. acknowledge button
   3. cancel button
<div align="left"><figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-e9d17a6466b984a25e45967bb9a52b5078322e9b%2FhmiExampelMsg.png?alt=media" alt=""><figcaption><p>example of a Warning message</p></figcaption></figure></div>
### HMI Message
Currently 3 types of messages can be definded: *Message*, *Warning* and *Failure*.
<div align="left"><figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-bf44dfd7195cacfa31287d1aa2abd7247005ff77%2Fhmimessage.png?alt=media" alt=""><figcaption></figcaption></figure></div>
* `Msg Type`
* `Use User Defined Color`: custom background color. By default are the following colors are set *Message* --> light grey; *Warning* --> yellow; *Failure* --> red
* `Background Color`: user defined background color of the message
* `Use User Defined Icon:` custom icon on the left hand side of the message
* `Message Icon:` user icon
* `Text`: text of the message
* `Size Text`: font size of the message
* `Show Time Stamp:` boolean, if true a time stamp is shown at the lower left corner
* `Modal` : if true this messag is modal and everything else is closed. You must acknowledge the message before anything else can be displayed.
* `Message Check Time:` duration after the message signal is checked again after canceling the message.
* `Cancel Button:` bool, if true a cancel button appears in the message
* `Acknowledge Button:` bool, if true a acknowledge button appears in the message
* `Show Button:` bool, if true a show button appears in the message
* `Message Camera`: Optional cinemachine camera for defining the camera position for this message.
* `Camera Show Details:` second cinemachine camera to focus on a certain detail
* `Highlighting:` bool, if true a user defined meshrenderer is highlighted when the message is active
* `Highlight Object` : list of objects (mesh-renderer) to highlight, when the message is active
* `Highlight Material:` material which is used to highlight
* `FlickerEffectMaterial:` bool, if true the material flickers
* `FlickerMaterial:` second material of the flicker effect
* `FlickerTime:` float for the flicker speed
* `SignalMessage` : signal of type PLC Output Bool. When the signal is true the message is active.
* `Signal Acknowledge` : signal of type PLC Input Bool. When the user confirms the message by using the button *"Acknowledge"* the message will be closed.
* `Signal Cancel` : Optional signal of type PLC Input Bool. When the user is pressing the cancel button the message will be put back on the last position of the stack.
* `References:` game object references to set all message information.
GET https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-message.md?ask=<question>&goal=<user_goal>
