> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/basics/user-interface/clean-restart-pro.md).
# Clean Restart (Pro)
## Clean Restart Unity
Automatically restart Unity with a clean cache to fix import issues and ensure clean configuration changes.
**Professional Feature**: Clean Restart Unity is only available in realvirtual Professional.
**realvirtual → Settings → Clean Restart Unity (Pro)**
### What It Does
1. Saves your current work
2. Closes Unity completely
3. Deletes the Library folder (Unity's cache)
4. Restarts Unity automatically
5. Reimports all assets with clean cache
{% hint style="warning" %}
This process takes 5-15 minutes depending on project size.
### When to Use
* **After configuration changes** (switching between Professional/Starter/etc.)
* **Import errors or corrupted assets**
* **Shader compilation problems**
* **Unexpected Unity behavior**
* **Before important builds**
### How to Use
1. Click **realvirtual → Settings → Clean Restart Unity (Pro)**
2. Confirm the dialog
3. Wait for Unity to restart and reimport assets
The process is fully automated - just wait for completion.
### For Non-Professional Users
If you don't have realvirtual Professional, you can achieve the same result manually:
#### Manual Clean Restart Steps:
1. **Save your work** in Unity
2. **Close Unity completely**
3. **Delete the Library folder** in your project directory
   * Navigate to your project folder
   * Delete the entire `Library` folder
4. **Restart Unity** and open your project
5. **Wait for reimport** (5-15 minutes)
#### Important Notes:
* The `Library` folder is Unity's cache - deleting it is safe
* Your project files (`Assets`, `ProjectSettings`) are never touched
* Unity will recreate the Library folder automatically
### Troubleshooting
**Unity won't close?** Wait 2 minutes, then use Task Manager (Windows) or Activity Monitor (Mac) to force-close Unity processes.
**File access errors?** Temporarily disable antivirus real-time scanning during the process.
**Long reimport times?** This is normal for large projects - be patient and let Unity finish.
GET https://doc.realvirtual.io/basics/user-interface/clean-restart-pro.md?ask=<question>&goal=<user_goal>
