Multiplayer (Pro, Deprecated)
Deprecated — moving to realvirtual WEB. Unity-based multiplayer (Netcode for GameObjects / Unity Relay) is deprecated. Real-time multiuser collaboration now runs in realvirtual WEB via the browser-based MultiplayerWEB relay: shared avatars, camera positions and live machine state across Unity and any browser client, with no networking setup and no port forwarding.
Real-time collaborative industrial automation simulation with support for multiple users and VR/AR integration.
Overview
The realvirtual Professional Multiplayer system enables multiple users to simultaneously interact with the same virtual commissioning scenario. Built on Unity Netcode for GameObjects with Unity Relay Service, it provides synchronized automation components, real-time material flow, and collaborative design review capabilities.
Key Features
Multi-user Collaboration: Scalable concurrent users in the same simulation
Real-time Synchronization: All automation components (Drives, Sensors, MUs, Sources) synchronized across clients
VR/AR Support: Full XR controller tracking and avatar representation
Industrial Integration: PLC signal synchronization and automation logic sharing
Cloud-based Connection: Unity Relay Service for secure peer-to-peer connections
System Requirements
Unity Packages
Unity Netcode for GameObjects: Core networking framework
Unity Transport (UTP): Network transport layer with DTLS encryption
Unity Services Core: Authentication and Unity Services integration
XR Interaction Toolkit (optional): For VR/AR functionality
Setup
1. Unity Services Configuration
Enable Unity Services in Project Settings → Services
Create Unity Project ID or link to existing project
Enable Relay Service in Unity Dashboard → Multiplayer → Relay
Enable Authentication for anonymous user sessions
2. Scene Setup
Add the Multiplayer Prefab to your scene from the realvirtual Professional package
The prefab contains all necessary components: NetworkManager, RelayConnectionManager, NetworkInitializer, and MultiuserWindow
All network prefabs are pre-configured and registered automatically
3. Automation Component Setup
The system automatically creates networked versions of:
Drives: Position and speed synchronization
Sensors: Occupancy state synchronization
MUs (Moving Units): Transform and identity synchronization
Sources: Material generation events
Signals: PLC signal values and states
Usage
Starting a Host Session
Open Multiuser Window via realvirtual → UI toolbar
Enter Player Name (stored locally)
Click "Host" to create session
Share Join Code with other users
Joining as Client
Enter Player Name
Input Join Code received from host
Click "Client" to join session
Connection Status
Connected: Successfully connected to multiplayer session
No Connection: Not connected or connection failed
Synchronized Components
NetworkDrive
Position Values: Current drive positions
Speed Values: Current drive speeds
Authority: Host controls drives, clients receive updates
Override Mode: Clients use PositionOverwrite and SpeedOverwrite
NetworkMU (Moving Units)
Transform: Position and rotation
Identity: LocalID, GlobalID, Name
Physics: Host maintains physics authority, clients use kinematic mode
Source Tracking: References to creating Source component
Physics objects must be kinematic on client machines to prevent conflicts with the host's authoritative physics simulation.
NetworkSensor
Occupancy State: Boolean occupied/free status
Network Mode: Clients automatically switch to network-controlled mode
Real-time Updates: Immediate sensor state propagation
NetworkSignal
Signal Values: All PLC signal types (PLCInputBool, PLCOutputFloat, etc.)
Bidirectional: Host-to-client signal synchronization
String-based: Universal value representation
NetworkPlayer
Player Names: Persistent player identification
XR Controllers: Left and right controller position/rotation sync
Avatar Visibility: First-person view (own avatar hidden)
Camera Tracking: Remote user viewpoint synchronization
VR/AR Integration
XR Setup
Install XR Interaction Toolkit
Configure XR Controllers as "LeftController" and "RightController" Groups
Enable XR Support in realvirtual-XR package
Test Controller Tracking before multiplayer sessions
Supported VR Systems
Meta Quest 2/3: Fully tested with Touch controllers
Other OpenXR Devices: Compatible through Unity XR system
Mixed Reality: Combine VR users with desktop users
Performance Considerations
Network Optimization
Change Detection: Only synchronizes data when values change
Update Frequency: FixedUpdate (50Hz) for smooth synchronization
Interpolation: Client-side smooth movement for controllers
Authority Model: Host maintains physics, clients display only
Best Practices
Monitor Simultaneous MUs: High MU counts can impact network performance depending on bandwidth
Use Appropriate Update Rates: Balance responsiveness with bandwidth (50Hz default)
Test Network Conditions: Verify performance under realistic network latency
Monitor Connection Quality: Use Unity Profiler for network analysis
Unity Transport Configuration: Use default settings for optimal Relay performance
Troubleshooting
Connection Issues
Unity Services Authentication: Verify anonymous authentication is enabled in Project Settings → Services
Relay Allocation: Check Unity Dashboard for Relay service status and CCU limits
Firewall Settings: Ensure UDP traffic is allowed (Unity Transport uses UDP)
Join Code Validity: Join codes expire after a timeout period (typically 10 minutes)
Package Installation: Verify Unity Netcode for GameObjects is properly installed
Synchronization Problems
Network Prefabs: Verify all automation components have corresponding network prefabs
Scene Path Resolution: Check that GameObject hierarchy matches between clients
Authority Conflicts: Ensure only host modifies authoritative data
Physics Conflicts: Verify client MUs are using kinematic rigidbodies
Performance Issues
Bandwidth Usage: Monitor network traffic in Unity Profiler
Update Frequency: Reduce FixedUpdate rate if needed
Object Count: Limit number of synchronized objects
Connection Stability: Test with realistic network conditions
API Integration
Custom Component Synchronization
To synchronize custom automation components:
See Also
Industrial Metaverse - VR/AR setup and configuration
Drive Components - Synchronized drive systems
Sensors - Networked sensor components
MU System - Moving unit synchronization
Interfaces - PLC communication in multiplayer scenarios
