> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/extensions/page-4/path-system.md).
# Path System
The Path System is part of the realvirtual.io simulation. It provides elements to construct different types of path systems based on [curves](https://game4automation.com/documentation/current/curve.html) and [lines](https://game4automation.com/documentation/current/line.html) (like AGVs, Power\&Free). The demo scene *DemoPathsystem\_UseCases* shows some possible use cases.
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-887858f2881a23118e7882283de8c9732a31bbcd%2Fsimulationusedcases.png?alt=media" alt=""><figcaption><p>Demo realvirtual.io simulation used cases</p></figcaption></figure>
## Implementing your own Path finding strategies <a href="#implementing-your-own-path-finding-strategies" id="implementing-your-own-path-finding-strategies"></a>
In Path Systems of automation systems very often the material flow strategies are very important for throughput and very often simulation models are build for developing and optimizing these strategies. Our library open and extendable and you can implement your own strategies. Please read the section [Path finding strategy](/extensions/page-4/path-system/path-finding.md) for more information about Path finding strategies.
## Snapping Objects
Elements for building path systems [curves](/extensions/page-4/path-system/curve.md) and [lines](/extensions/page-4/path-system/line.md) have Snap Points. Snap points allow objects to be placed exactly next to each other at the appropriate points.
Please note that snap points require *Gizmos* to be enabled. To do this, click *Gizmos* in the upper right corner of the scene.
<div align="left"><figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-9c1c6e4c59bdb51aa4f32ae1b71de65aea87920a%2FPathSnapPoints.png?alt=media" alt=""><figcaption></figcaption></figure></div>
## Path System Components <a href="#path-system-components" id="path-system-components"></a>
#### Line
The [line](/extensions/page-4/path-system/line.md) moves the MUs along a linear path from start to finish.
#### Curves
The [curve](#curves) moves the MUs on a circular path from start to finish.
#### Station
The [workstation](/extensions/page-4/path-system/workstation.md) stops the MU on a path for a specified time. It can be extended by additional stations (e.g. to a loading or unloading station).
#### Catcher
The [Catcher](#catcher) catches MUs that are under “physical control” and loads them onto a path.
#### PathMover
The [Path Mover](#pathmover) is responsible for moving the [MUs](/components-and-scripts/mu-movable-unit.md) along the path.
GET https://doc.realvirtual.io/extensions/page-4/path-system.md?ask=<question>&goal=<user_goal>
