> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-tab.md).
# HMI Tab (Deprecated)
realvirtual.io Professional
{% hint style="danger" %}
**Deprecated — no realvirtual WEB equivalent.** This Unity uGUI tab/panel overlay is deprecated and is **not exported to realvirtual WEB**. The browser-based 3D-HMI is not built from these in-scene tabs: [**realvirtual WEB**](/extensions/realvirtual-web.md) provides its own HMI framework (WebSensor, WebError, KPI and message panels, and a React overlay/plugin layer with configurable slots). Build browser HMIs there rather than porting this tab setup.
An HMI tab is a user interface overlay that includes multiple elements. We recommend that you start your own tabs based on the existing Tabs within the HMI Demoscene
Activation of the tabs can be done either through a button a dropdown menu or a PLC-signal.
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-db87e0f28b2bd0221d44381aec3b698ea6188ef4%2FhmiControl.png?alt=media" alt=""><figcaption></figcaption></figure>
## Tab properties
<div align="left"><figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-ca005c53ed0b2c21645870166934a6a6a8cc6946%2FHMI_Tab.png?alt=media" alt=""><figcaption><p>HMI Tab properties</p></figcaption></figure></div>
* `Tab Activated:` Boolean if the tab is active.
* `Modal`: true, if this Tab can't be opened with other Tabs in same time. If it is modal other tabs will be closed automatically.
* `Camera:` Cinemachine camera which is activated when the tab is activated
* `SignalTab`: PLC Output bool signal which activates / deactivate the tab
## Custom Tabs
To create a custom tab pull the prefab "HMI\_Tab" in your scene and unpack the prefab. (Right-click on the game object and choose Prefab/unpack completely).
<div align="center"><figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-0a27e353499215005dbc8802a501481e165aaa14%2Fhmitabstructure.png?alt=media" alt=""><figcaption><p>HMI Tab structure</p></figcaption></figure></div>
Do not rename the GameObjects within the HMI-prefab. The tab's content consists of two areas: OverlayContent for HMI-elements displayed as a screen overlay, and WorldspaceContent without a Canvas where elements automatically receive a canvas in "WorldSpace" render mode. These elements will be placed in the 3D scene."
If you use [HMI-messages](/components-and-scripts/scene-interaction/hmi-components-pro/hmi-message.md) in one of the areas the HMI-tab will detect this and manage them.
## HMI TabButton
The HMI TabButton is a button which can be placed on the UI for enabling and disabling Tabs.
<div align="left"><figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-7a89a6e149d0e3d5d1d492426df93788769b4205%2FhmitabButton.png?alt=media" alt=""><figcaption></figcaption></figure></div>
* Tab: HMI tab which is controlled by the button
* Connected Tab Active: Background color of the button when the tab is active.
* SignalButtonOn: signal to turn the Button on.
* Button Image: sprite image of the button
* Color 1 Signal to Color 3 Signal and Colors: the button can change the color depending on which signal is currently true.
* Image1 to Image3: can be used to change the image of the button depenting on the PLC state
GET https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-tab.md?ask=<question>&goal=<user_goal>
