Old Demo Model
First experiences with realvirtual.io based on the demo model
This is a description of the old demo model which was used until realvirtual 6.0.1. It is still inside of our delivery and you find it under Assets/realvirtual/Scenes/DemoRealvirtualOld.unity
The old demo model looks like this:
Start the old demo model
The demo model can be started with the play button. You will get a Scene view and a Game View. If the Game View window is not opened, it will open automatically on start. You can navigate in the scene in both views. The Game View is a preview of the later on the compiled version of Unity. On low performance computers the Game View is a little bit slower, than in the final Player version. On good performing computers the difference is negligible.
Mouse navigation
You can navigate in the scene with the mouse or keyboard:
Right Mouse Button
Rotate scene
Middle Mouse Button Wheel
Zoom in and out
Middle Mouse Button
Pan in a direction
Right Arrow Key
Move the scene to the right
Left Arrow Key
Move the scene to the left
Up Arrow Key
Move the scene up
Down Arrow Key
Move the scene down
Shift + Up Arrow Key
Zoom into the scene
Shift + Down Arrow Key
Zoom out of the scene
T
Top view
F
Front view
B
Back view
L
Left view
R
Right view
F1,F2,F3
Saved views which can be extended
Touch navigation
It is also possible to use touch navigation on mobile devices or windows computers with touch screens.
You can pan with one or two fingers. With two fingers it is possible to rotate, pan and zoom. With three fingers the scene can be tilted.
Space Navigator
If you have a 3D mouse from 3DConnextion you can use the mouse to navigate in the 3D scene.
Some more information about the demo model
Game4automation object (prefab)
The first step for creating a new model, is to place the Realvirtual prefab into the scene. This object handles the overall settings, provides a base plate, the basic lighting and the scene navigation in game mode. You need to use this in every model you build. You can change the parameters of the base plate or the lighting by clicking on the objects. This will override the inherited properties from the realvirtual.io Asset. For more information about Prefabs and inheritance please check the Unity documentation about Prefabs or check the Unity video tutorial .
3D Components
The demo model is based on several pre-prepared 3D components like the conveyor, the handling system and the robot. These components were created just for demo purposes.
With realvirtual.io Professional you can import your own CAD data based on step files. Please check the section CADImport.
The 3D components in the demo scene are Handling, ConveyorCan, ConveyorBox, Cabinet, Robot)
Interfaces
The model is equipped with one demonstration Interface. It is an S7 Interface to the Siemens Controller. For more information about interfaces please check Section Interface. For demo purposes, in the demo model the interface is turned off so that the model can run in the absence of any external software connections. Nevertheless, signals are created for the interface, and the full model is controlled by a script substituting for a PLC, to handle the signal events.
Signals
Each interface can be of a certain type (S7TCP, Shared Memory, PLCSIM Advanced and so on) and can contain several signals. Signals are usually imported from the counterpart of the interface (for example if Simit is up and running, the signals can be automatically imported from Simit) or signals can be manually created based on the prefabs. See more about Signals and Signal types in Section Interface. In the model you will find several signals, for example CanGripperClosed,GantryYStart and so on. On a signal you always see the signal value in the Hierarchy view. For example False and True for boolean signals. PLC-Inputs (which means outputs from Unity) are in red. PLC-Outputs (which means inputs to Unity) are in green.
Sources and MUs
The objects, which are moving based on Physics, are called MU (= movable unit) in realvirtual.io. The model has two sources. One for the cans (CAN)= and one for the blue plastic box (PlasticBox). The Sources are automatically creating a copy of itself (this is called spawning in Unity). It is always good practice, to place the newly created MUs as sub object of a special object in the hierarchy. In the demo model this is the object MU. During simulation runtime you will find all dynamically created MUs under MU.
PLCs
Because we don't have real PLCs connected to the demo model, we programmed some simple control logic to drive the model. These control logics are communicating with the behavior models of the drives and sensors by using the Signals in the interface section.
Control logics inside the model are using signals for controlling the model mainly for demo purposes. If you just want to control the model, you can also control the public properties on the drives or sensors directly. See more in Section Defining Logic.
In the Demo model we used Unity Scripting for defining the "PLC" logic. You can also use our Logicsteps, Unity Visual Scripting or Playmaker if you would like to use more visual approaches.
The control logics inside the model are using signals for controlling the model mainly for demo purposes. If you just want to control the model, you can also control the public properties on the drives or sensors directly. See more in Section PLC.
UI
You can add UI components to a scene. These UI components can be connected to signal inputs or outputs of the PLC. For example, this is very useful when you want to replace real buttons with virtual ones in your model. In the UI components you find several elements to control the model. During simulation you can see in the Game-Window the UI elements:
The UI elements can be opened and closed by clicking on the slider button in the middle of the bottom corner of the screen. Additional buttons and tabs can be added to your own models as you would like.
© 2025 realvirtual GmbH https://realvirtual.io - All rights reserved. No part of this publication may be reproduced, distributed, or transmitted in any form or by any means, including printing, saving, photocopying, recording, or other electronic or mechanical methods, without the prior written permission of the publisher.
