HMI components (Pro, Deprecated)
only available in realvirtual.io Professional
Deprecated — Unity-only, superseded by realvirtual WEB. These uGUI HMI components are deprecated and are not read by realvirtual WEB — the browser-based 3D-HMI is a separate, re-architected system, not a port of these components. Migration status per component:
HMI Marker → WebSensor and HMI Message → WebError / WebDiagnostics + CustomRuntimeInstruction — equivalent capability exists in realvirtual WEB via new components; use those.
HMI Value / HMI Text — shown in the browser via hover tooltips, signal chips, KPI cards and WebSensor labels; there is no authored per-object overlay.
HMI Slider / Switch / Pushbutton / DropDown / Tab and the HMI panel system — interactive operator widgets with no realvirtual WEB equivalent; the browser HMI is built from WebSensor / WebError, KPI and message panels, and the React plugin layer.
See realvirtual WEB, the single platform for delivering browser-based 3D-HMIs.
Please install CINEMACHINE via the package manager. Cinemachine is needed for controlling the camera position for HMI messages. Please also make sure that "CINEMACHINE" is added as Scripting Define Symbols (Project Setting > Player > Scripting Define Symbols)
HMI components are prefabricated UI components used to create 3D interfaces for automation systems. They can be connected to signals and integrated with various PLC interfaces such as S7TCP, TwinCAT, TwinCAT HMI, EthernetIP, OPCUA and more.
Overview
HMI components are organized into "Tabs" which are overlays on the 3D scene and can be opened and closed by buttons or certain events. All HMI components can be connected with Signals and by this the can control or display scene or machine data. Certain HMI components can utilize Unity's Cinemachine to manage multiple cameras and camera positions. To enable this functionality, ensure that you have the required compile definition in place
The following components can be used for building individual HMI interfaces:
Supported Use Cases
HMI components offer various use cases when combined with real machine controls. These include:
Displaying custom texts, such as IDs of machine components at 3D positions
Changing data on the industrial control by pushbuttons, sliders and pulldowns and switches
Representing sensor states as colored elements (booleans) at 3D positions
Showing values like axis positions and temperatures as 2D overlays or within the 3D scene
Presenting messages (normal, warning, and failure) that are connected to PLC outputs and inputs, allowing for acknowledgments. These messages can trigger specific 3D views and initiate custom animation sequences based on logical steps.
Demo scene
The HMI demo scene contains most of the realvirtual.io HMI functions. You find the demo scene realvirutal/professional/HMI/Demo/DemoHMI. Within the Demo folder you find also a scene with an example how to set up your own HMI. The scene "emptyHMIscene" is an example which can be used as a HMI prefab. The basic elements of this scene are available as prefabs.
Common properties
The following attributes are available at all interactive HMI components.
Color: standard of the element when no user interactionColor MouseOver: color when the mouse pointer is on the elementAlpha Visibility: determine the occupancy of the elementEventOnValueChanged: Unity event when the value of the connected signal is changing
HMI Controller
The HMI controller must be added as a component to the topmost GameObject in the HMI area. It manages camera position changes and can also restrict mouse navigation for the user.
