CAD Checker (Pro)
Analyzing large CAD data for performance bottlenecks
With CAD Checker an imported CAD file can be checked. This is mainly usefull for verly large assemblies for detecting performance bottlenecks.
This includes
calculation of triangles, static meshes, and non-static meshes
detection of the largest meshes for further optimization
detection of unnecessary mesh duplicates for performance optimization
CAD Checker Window
To open the CAD Checker window please select Tools > realvirtual > CAD Checker (Pro) in the realvirtual.io menu. This will open this window:
In the window, you can get a quick overview of the triangles in the model and the optimization possibilities.
First, you will need to select the level of the model you want to check under Check this. If you select upper part naming the name displayed in the first column of the mesh list is the name of the Gameobject one level above the mesh itself. This is the usual setup for most imported CAD data.
Next, you should select if you want to see all occurrences in the model (what means all identical meshes) in one line or as separate lines. To detect duplicates you should select Show Occurencies.
Now you can see the total number of meshes and triangles in the model. The list is displaying you all meshes sorted by the total number of polygons. This means that _CarrierA in the model has in total 372912 Polygons with 34 occurrences. That means that 34 identical meshes are in the model. These meshes make 372912 Polygons. But there are also 10 Duplicates in the model. Duplicates are identical meshes with identical positions. Usually, you should prevent to have duplicates in the model because they are normally unnecessary.
With Show you can Ping the object and with Filter you can display all the components isolated. With Select you can select all components and with Duplicates only the duplicates are selected.
© 2025 realvirtual GmbH https://realvirtual.io - All rights reserved. No part of this publication may be reproduced, distributed, or transmitted in any form or by any means, including printing, saving, photocopying, recording, or other electronic or mechanical methods, without the prior written permission of the publisher.
