> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/components-and-scripts/performance-tools/combine-meshes-pro.md).
# Combine Meshes (Pro)
Further performance improvements. Only available with the professional version.
## Combine Meshes
### Introduction
After importing CAD data into a Unity scene, you often end up with a deeply nested and complex GameObject hierarchy. Meshes may be stored directly in the scene or as assets in your project, depending on the import method.
To prepare the scene for real-time applications and ensure optimal performance, it's often beneficial to **reduce the number of GameObjects** and **minimize draw calls**. This can be achieved using the `Combine Meshes` utility—especially when meshes share a **limited and unified set of materials** that already exist as assets.
### Overview
The `Combine Meshes` utility enables you to **combine multiple meshes into a single mesh**, significantly reducing draw calls and improving rendering performance.
> ℹ️ **Note:** This is particularly useful for:
> * **Reusable prefabs**, where a simplified internal structure is desired.
> * **Final optimization at the end of a project**, where rendering performance is critical.
> ⚠️ **Warning:** After combining, **you will no longer have access to the individual mesh parts**. Consider creating a backup or duplicating the original GameObjects before using this function.
Here is an example of an unoptimized scene:
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-b475d54cc4596d7e414dda612c8ddb75b014f2b0%2Fmesh-unoptimized.png?alt=media" alt=""><figcaption><p>Unoptimized structure after CAD Import</p></figcaption></figure>
### Kinematic and Drive Group Awareness
The `Combine Meshes` utility **automatically respects kinematic groupings and drive mechanisms** defined in the scene. This means:
* Only **non-moving parts** or parts that move **together as a single unit** are combined.
* Meshes involved in **kinematics or driven motions** (e.g., robotic arms, sliding doors) are **not combined across movement boundaries**, preserving functionality.
This ensures that performance optimizations do not interfere with the behavior of simulated machinery or driven components.
### How to Use
1. **Select GameObjects**\
   In the Unity Hierarchy, select the GameObjects whose meshes you want to combine.
2. **Run Combine Meshes**\
   Right-click on the selection and choose:\
   \&#xNAN;**`realvirtual/Combine Meshes`**
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-9a822e888c17c125be2b7ae0d3c6f1e05629ac99%2Fmesh-combinemeshes.png?alt=media" alt=""><figcaption><p>Combine meshes in the Gameobject context menu</p></figcaption></figure>
3. **Result**\
   The selected GameObjects will have their meshes merged into a single optimized mesh, improving rendering performance.
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-ea8ac80e46df9779c5c62003f5358a814519ebc8%2Fmeshcombined.png?alt=media" alt=""><figcaption><p>Simplified structure after mesh combine</p></figcaption></figure>
> 💡 **Tip:** For best results, ensure that all selected meshes use shared materials that are already available as assets in your project.
### Next Step: Create Prefab
If you intend to **reuse the combined mesh** as a component in other scenes or projects, continue with the [Create Prefab](/components-and-scripts/performance-tools/create-prefab-pro.md) section. This will guide you through turning the optimized GameObject into a reusable, self-contained prefab.
GET https://doc.realvirtual.io/components-and-scripts/performance-tools/combine-meshes-pro.md?ask=<question>&goal=<user_goal>
