> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/basics/user-interface/quick-edit.md).
# Quick Edit
## What's New in Version 6.0.3
* **New Toolbar Integration**: QuickEdit can now be activated via the realvirtual toolbar buttons in Scene View
* **Modern UI Toolkit**: Complete visual redesign with improved styling
* **Better Organization**: Components grouped by functionality
* **Enhanced Pivot Tools**: Integrated MovePivot functionality with dedicated toolbar button
* **Improved Performance**: Faster rendering and responsiveness
* **Dark Theme**: Professional dark interface matching Unity's theme
* **Dual Activation**: Both toolbar button and F1 hotkey activation methods available
**Updated in Version 6.0.3**: QuickEdit has been redesigned with modern UI Toolkit and enhanced overlay integration.
## Overview
The QuickEdit overlay is a powerful Scene View tool that provides instant access to essential realvirtual components and functions. The redesigned interface features a modern, dark-themed UI with organized component categories and enhanced pivot tool integration.
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-d9851f1a7c59a4a0c5a7c07f849cfc6a1a73209e%2Fquickedit-new-ui-toolkit.png?alt=media" alt="New QuickEdit UI Toolkit Interface"><figcaption><p>QuickEdit overlay with modern UI Toolkit design and enhanced component organization</p></figcaption></figure>
## Key Features
### Component Categories
The new QuickEdit interface organizes components into logical groups:
* **Positioning Tools**: Local, Global, Pivot controls with X-, Y+, Z+ axis buttons
* **Ground Operations**: "To Ground", "Pivot to B...", "Align Y Up"
* **Object Management**: "Empty" and "To Empty" for GameObject creation
* **Core Components**: Transport Surface, Sensor, Axis, Kit
* **Interaction**: Grip, Fixer, Joint
* **Motion Systems**: Simple Drive, Cylinder, Gear, CAM, Follow Position, Destination Drive, Drive Erratic, Drive Speed
### Enhanced Controls
* **Pivot Integration**: Direct access to pivot manipulation tools
* **Speed Control**: Target Speed slider with precise value input
* **Playback Controls**: Back, Stop, Forward buttons for simulation control
* **Context-Sensitive**: Available functions adapt to selected object(s)
## How to Use
### Activation Methods
**Method 1: Toolbar Button (New in 6.0.3)** The QuickEdit overlay can now be activated via the new realvirtual toolbar in the Scene View:
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-b7a48a414fc5bd9d75017411b808861e87bc5579%2Fquickedit-toolbar-buttons.png?alt=media" alt="realvirtual Toolbar Buttons"><figcaption><p>New realvirtual toolbar with Quick Edit and Move Pivot buttons in Unity Scene View</p></figcaption></figure>
**Method 2: Keyboard Shortcut** Press **F1** in Scene View to toggle QuickEdit overlay (traditional method)
### Usage Steps
1. **Activation**: Click the **Quick Edit** button in the realvirtual toolbar or press **F1**
2. **Selection**: Select objects in the Scene View or Hierarchy
3. **Component Addition**: Click component buttons to add to selected objects
4. **Pivot Control**: Use positioning tools for precise object manipulation
5. **Speed Adjustment**: Use the Target Speed slider for drive components
## Drive Control Settings
When working with Drive components, QuickEdit provides controls for setting up drive parameters that will be used during Play Mode:
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-e965e271082440963493000e9217a124be203289%2Fquickedit-drive-controls.png?alt=media" alt="QuickEdit Drive Controls"><figcaption><p>Drive control section for configuring target speed and jog settings for Play Mode</p></figcaption></figure>
### Control Settings
* **Back (◀)**: Sets the drive to jog backward when Play Mode starts
* **Stop (■)**: Sets the drive to stop/idle state for Play Mode
* **Forward (▶)**: Sets the drive to jog forward when Play Mode starts
### Speed Configuration
* **Target Speed**: Sets the target speed value for the selected drive (shown as "100" in mm/s)
* **Pre-Play Configuration**: Speed setting is applied to the drive component for use in Play Mode
* **Units**: Speed configured in millimeters per second (mm/s)
### Usage for Play Mode Preparation
1. **Select Drive**: Click on a Drive component in the Scene View or Hierarchy
2. **Set Speed**: Configure the Target Speed value for Play Mode operation
3. **Set Direction**: Choose Back, Stop, or Forward for initial Play Mode behavior
4. **Enter Play Mode**: The drive will use the configured settings when simulation starts
This feature is particularly useful for:
* **Play Mode Setup**: Configure drive behavior before entering Play Mode
* **Speed Configuration**: Set target speeds for automation sequences
* **Initial State Setting**: Define whether drives should jog forward, backward, or remain stopped
* **Simulation Preparation**: Prepare drive parameters for testing automation logic
## QuickEdit in Play Mode
During Play Mode, QuickEdit transforms into a powerful real-time control and monitoring interface, allowing you to interact with drives and control simulation parameters while the automation is running:
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-bc05c0339013881226a7e86c0fcbbe737d311f03%2Fquickedit-playmode-active.png?alt=media" alt="QuickEdit in Play Mode"><figcaption><p>QuickEdit during Play Mode showing active drive controls, timescale adjustment, and real-time drive monitoring</p></figcaption></figure>
### Simulation Controls
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-b8627f0d1fc621fdf2bfaad331988787050f60f1%2Fquickedit-simulation-speed-controls.png?alt=media" alt="Simulation Speed Controls"><figcaption><p>Close-up view of Timescale and Drive Speed Override controls for simulation speed adjustment</p></figcaption></figure>
#### Timescale Control
* **Timescale Slider**: Adjust simulation speed from slow motion to accelerated time (shown: 368.8)
* **Current Value Display**: Shows current timescale multiplier in real-time
* **Slider Range**: From 0.1 (slow motion) to max (very fast simulation)
* **Real-time Adjustment**: Changes apply immediately to entire simulation speed
#### Drive Speed Override
* **Global Speed Control**: Override all drive speeds with a master multiplier (shown: 1.0)
* **Independent Control**: Separate from timescale - affects only drive movements
* **Slider Range**: From 0 (stopped) to max speed multiplier
* **Testing Feature**: Ideal for testing automation sequences at different drive speeds
### Active Drive Monitoring
#### Drive Selection and Control
* **Drive List**: Shows currently selected or active drives in the scene
* **Real-time Status**: Displays current drive positions and states
* **Position Display**: Shows exact drive positions (e.g., "A3: 205.8°")
* **Live Updates**: Values update continuously during simulation
#### Manual Drive Control
* **Back (◀)**: Manually jog selected drive backward during simulation
* **Stop (■)**: Stop selected drive immediately
* **Forward (▶)**: Manually jog selected drive forward during simulation
* **Override Automation**: Manual controls can override automated sequences
### Real-time Features
#### Visual Feedback
* **Active Drives**: Highlighted drives show which components are currently moving
* **Position Indicators**: Real-time position values displayed for monitoring
* **Status Colors**: Visual indicators show drive states (moving, stopped, etc.)
#### Interactive Control
* **Live Adjustment**: All controls respond immediately during simulation
* **No Pause Required**: Adjust parameters without stopping the simulation
* **Multi-drive Support**: Monitor and control multiple drives simultaneously
### Use Cases in Play Mode
* **Speed Testing**: Adjust timescale to observe automation at different speeds
* **Drive Override**: Take manual control of drives during automated sequences
* **Performance Tuning**: Test different speed settings in real-time
* **Debugging**: Stop specific drives to isolate issues during simulation
* **Training**: Demonstrate system behavior at various speeds
* **System Optimization**: Fine-tune drive speeds and timing while observing results
### Key Differences from Edit Mode
| Feature              | Edit Mode               | Play Mode                          |
| **Drive Controls**   | Set initial parameters  | Real-time drive control            |
| **Speed Settings**   | Configure for Play Mode | Active speed override              |
| **Timescale**        | Not available           | Real-time simulation speed control |
| **Position Display** | Static values           | Live updating positions            |
| **Purpose**          | Preparation and setup   | Active simulation control          |
## Configuration
### Aligning Pivot Points
To align pivot points, you can use the Pivot button. This window will open the Move Pivot window. For more information check the page [Move Pivot.](/basics/user-interface/move-pivot-points-pro.md)
### Changing Quickedit Visibility
You can toggle the visibility of the Quickedit window on/off using the Hotkey F1. If you wish to change the hotkey, you can do so within the realvirtual.io controller inside the scene.
![](https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-e37caae068144c11f04eda27efa0ece7415123d6%2Fquickedit-hotkey.png?alt=media)
## Prerequisites
* Unity 6000.0.28f1 (Unity 6) or later with realvirtual framework
* Scene must contain a realvirtual.io controller component
* Basic familiarity with Unity Scene View interface
## Troubleshooting
* **QuickEdit not appearing**: Ensure F1 hotkey is enabled in the realvirtual.io controller settings
* **Toolbar buttons missing**: Verify Unity 6+ installation and proper realvirtual framework setup
* **Drive controls unresponsive**: Check that drive components are properly configured and selected
* **Outdated interface**: Ensure you're using realvirtual version 6.0.3 or later for the new UI Toolkit design
## See Also
* [Move Pivot Points (Pro)](/basics/user-interface/move-pivot-points-pro.md) - Advanced pivot manipulation tools
* [Reparenting Tool (Pro)](https://github.com/game4automation/doc/blob/doc/basics/user-interface/reparenting-tool-pro.md) - Hierarchy management
* [Runtime UI](/basics/runtime-ui.md) - Play Mode interface controls
GET https://doc.realvirtual.io/basics/user-interface/quick-edit.md?ask=<question>&goal=<user_goal>
