> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/basics/runtime-ui/runtime-debugger.md).
# Debug Console
Debugging without the Unity Editor in a Build
The **Debug Console** in realvirtual.io is based on the [Unity Ingame Debug Console](https://github.com/yasirkula/UnityIngameDebugConsole), which is licensed under the **MIT License** (Copyright © Süleyman Yasir KULA).
This tool provides **full access to Unity’s console log in a build** and allows the execution of **custom commands**. It is particularly useful for **debugging** and for modifying specific **player application properties** during runtime.
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-b2fa844831f21845d1f881758259be4d76b7ebdb%2F48eE07eLQY.png?alt=media" alt=""><figcaption><p>Debug Console</p></figcaption></figure>
## How to Use the Debug Console
1. **Add the Debug Console Prefab**\
   To enable the Debug Console in your project, add the prefab located at:
   Assets/realvirtual/UIPrefabs/DebugConsole.prefab
   into your scene hierarchy.
2. **Opening the Debug Console**\
   While running the simulation, you can open the Debug Console by clicking in the **bottom-left corner** of the screen.
3. **Console Log Indicators**
   * If there are any console log entries, small **icons** and a **log count** will appear to notify you.
   * You can review **warnings, errors, and other logs** in real time.
4. **Executing Commands**\
   The Debug Console also supports **custom commands**, allowing you to trigger specific functions or modify application settings directly.
## Console Commands
To see a full list of available commands, type the following in the Debug Console's input field:
bashKopierenBearbeitenhelp
**Available Commands**
| Command                 | Description        |
| **ConnectOff**          | Disables Connect Mode. This setting is saved for the next start.        |
| **ConnectOn**           | Enables Connect Mode. This setting is saved for the next start.        |
| **DebugOff**            | Turns off Debug Mode. The player must be restarted for this change to take effect. *Please note: Not all components take care about Global Debug Mode.*                                           |
| **DebugOn**             | Turns on Global Debug Mode in realvirtualController. The player must be restarted for this change to take effect. *Please note: Not all components take care about Global Debug Mode.*            |
| **DeletePrefs**         | Deletes all PlayerPrefs (everything what is saved with [RuntimePersistence](/basics/runtime-ui/runtime-persistence.md) or saved manually via script). The model returns to the standard settings. |
| **help**                | Prints all available commands.        |
| **help \[commandName]** | Prints detailed information about the specified command.        |
| **InspectorOff**        | Disables the Runtime Inspector. The player must be restarted for this change to take effect.        |
| **InspectorOn**         | Enables the Runtime Inspector. The player must be restarted for this change to take effect.        |
For more information about implementing your own commands please check <https://github.com/yasirkula/UnityIngameDebugConsole?tab=MIT-1-ov-file>
GET https://doc.realvirtual.io/basics/runtime-ui/runtime-debugger.md?ask=<question>&goal=<user_goal>
