> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/components-and-scripts/scene-interaction/tooltip-pro.md).
# Tooltip (Pro)
Disppaying tooltips in the scene.
{% hint style="warning" %}
This feature is only available in realvirtual.io Professional
The **RuntimeTooltip** system allows you to display contextual tooltips in your simulation, helping users understand the function or content of scene objects at runtime.
<figure><img src="https://260262196-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FpYxFg97YnJX96UzNNTSd%2Fuploads%2Fgit-blob-fa3bc8fa36bcb3f29302f853abd6cb34a27e284d%2Ftooltip.png?alt=media" alt=""><figcaption><p>Runtime tooltip</p></figcaption></figure>
#### Features
* Works with any 3D object in the scene
* Fully supports **TextMeshPro rich text** (bold, color, line breaks)
* Dynamically displayed on hover or selection
* Easy to integrate via prefab
## Required Components
**1. Tooltip Controller (Scene-Level)**
You must add the Tooltip Controller to your scene. This controller handles the positioning and display of all tooltips.
> 📦 **Prefab**:\
> `Assets/realvirtual/Professional/SceneSelection/TooltipController.prefab`
Drag and drop this prefab into your scene to enable the tooltip system.
**2. RuntimeTooltip Script (Object-Level)**
Attach the `RuntimeTooltip` script to any GameObject you want to annotate with a tooltip.
**Steps:**
1. Select the target GameObject (e.g., a cabinet).
2. Add the component: `Runtime Tooltip (Script)`
3. Enter your tooltip text in the **Text** field using TextMeshPro for formatting if needed.
**Example:**
```html
<b><color=#FFD700>Cabinet</color></b>\nContains control electronics and power supply
GET https://doc.realvirtual.io/components-and-scripts/scene-interaction/tooltip-pro.md?ask=<question>&goal=<user_goal>
