# Page Not Found
The URL `components-and-scripts/hmi-components` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Motion and Kinematic](https://doc.realvirtual.io/components-and-scripts/motion.md)
- [UI components](https://doc.realvirtual.io/components-and-scripts/scene-interaction/ui-components.md)
- [MU, Source and Sink](https://doc.realvirtual.io/components-and-scripts/mu-movable-unit.md)
- [HMI components (Pro, Deprecated)](https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro.md)
- [Interfaces](https://doc.realvirtual.io/components-and-scripts/interfaces.md)
GET https://doc.realvirtual.io/components-and-scripts/motion.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/components-and-scripts/motion.md`).
