# Page Not Found
The URL `basics/user-interface/material-window` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Material Window (Pro)](https://doc.realvirtual.io/basics/user-interface/material-window-pro.md)
- [Selection Window (Pro)](https://doc.realvirtual.io/basics/user-interface/selection-window.md)
- [Hierarchy Window](https://doc.realvirtual.io/basics/user-interface/hierarchy-window.md)
- [Duplicate Finder (Pro)](https://doc.realvirtual.io/basics/user-interface/duplicate-finder.md)
- [Move Pivot Points (Pro)](https://doc.realvirtual.io/basics/user-interface/move-pivot-points-pro.md)
GET https://doc.realvirtual.io/basics/user-interface/material-window-pro.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/basics/user-interface/material-window-pro.md`).
