# Page Not Found
The URL `extensions/page-4/realvirtual.io-path-system/workstation` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Workstation](https://doc.realvirtual.io/extensions/page-4/path-system/workstation.md)
- [Line](https://doc.realvirtual.io/extensions/page-4/path-system/line.md)
- [Curve](https://doc.realvirtual.io/extensions/page-4/path-system/curve.md)
- [Catcher](https://doc.realvirtual.io/extensions/page-4/path-system/catcher.md)
- [Path finding](https://doc.realvirtual.io/extensions/page-4/path-system/path-finding.md)
GET https://doc.realvirtual.io/extensions/page-4/path-system/workstation.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/extensions/page-4/path-system/workstation.md`).
