# Page Not Found
The URL `basics/user-interface/group-manager` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Group Manager](https://doc.realvirtual.io/basics/runtime-ui/group-manager.md)
- [Group Assignment Tool (Pro)](https://doc.realvirtual.io/basics/user-interface/group-assignment-tool-pro.md)
- [Measurement (Pro)](https://doc.realvirtual.io/basics/user-interface/measurement-pro.md)
- [Model Checker](https://doc.realvirtual.io/basics/user-interface/model-checker.md)
- [Editor User Interface](https://doc.realvirtual.io/basics/user-interface.md)
GET https://doc.realvirtual.io/basics/runtime-ui/group-manager.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/basics/runtime-ui/group-manager.md`).
