# Page Not Found
The URL `components-and-scripts/signal-manager` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Signal Manager](https://doc.realvirtual.io/components-and-scripts/interfaces/interface-tools/signal-manager.md)
- [Interfaces](https://doc.realvirtual.io/components-and-scripts/interfaces.md)
- [Picking and Placing MUs](https://doc.realvirtual.io/components-and-scripts/picking-and-placing-mus.md)
- [Sensors](https://doc.realvirtual.io/components-and-scripts/sensors.md)
- [Volume Tracking (Pro)](https://doc.realvirtual.io/components-and-scripts/volume-tracking-pro.md)
GET https://doc.realvirtual.io/components-and-scripts/interfaces/interface-tools/signal-manager.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/components-and-scripts/interfaces/interface-tools/signal-manager.md`).
