HMI Switch
realvirtual.io Professional
The HMI Switch works as toggle switching the connected Signal status between true and false. To use it with the render mode "Worldspace" you need the HMI-PanelWorldSpace as parent.
![](https://doc.realvirtual.io/~gitbook/image?url=https%3A%2F%2F260262196-files.gitbook.io%2F%7E%2Ffiles%2Fv0%2Fb%2Fgitbook-x-prod.appspot.com%2Fo%2Fspaces%252FpYxFg97YnJX96UzNNTSd%252Fuploads%252FULuqIgCfjVMBaJJWE0Ff%252FhmiSwitchExample.png%3Falt%3Dmedia%26token%3D638c4abc-8b90-46b3-98de-f4bb6670a235&width=768&dpr=4&quality=100&sign=66e880a9&sv=1)
Properties
![](https://doc.realvirtual.io/~gitbook/image?url=https%3A%2F%2F260262196-files.gitbook.io%2F%7E%2Ffiles%2Fv0%2Fb%2Fgitbook-x-prod.appspot.com%2Fo%2Fspaces%252FpYxFg97YnJX96UzNNTSd%252Fuploads%252FEmBzYxCKaFyelPlOqEIf%252FHMISwitch.png%3Falt%3Dmedia%26token%3D7acb5487-c42b-4e71-8de1-2893d8b4255d&width=768&dpr=4&quality=100&sign=fd2ae5d8&sv=1)
ColorOn
: color in case of Signal status trueSignalOn
: PLCInputBool signal connected to the ButtonSignalInit
: PLCOutputBool signal for the value of the Switch when the application startsText
: Button textText Size
: font sizeIsOn
: read only for the current state of the switch
