HMI Marker
HMI-Marker are used to visualize the state of a signal. They have to be within the "Worldspace"-Section of a tab.
The current prefab provides a simple cube as a marker object. But it is possible to customize this with a own mesh elements. The structure of the marker includes currently a game object "Icon" to map a user defined icon on the marker object.
Properties
  • Color On: Material which is active when the connected signal is high
  • Color Off: Material which is active when the connected signal is low
  • ObjectTracking: boolean wether the value object is placed next to a game object within the scene or not
  • TrackedObject: game object within the scene which position is used to place the HMI value information
  • Offset : Offset position to the object in up direction.
  • EnableGameObjectOnSignalTrue: sets the defined game object active if the signal value is true
  • EnableGameObjectOnSignalFalse: sets the defined game object active if the signal value is false
  • Signal Bool: signal whose values are indicated by the marker
