> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/extensions/realvirtual-web/supported-components.md).
# Supported Components
Which realvirtual components are exported to GLB and run in realvirtual WEB
## Overview
realvirtual WEB reconstructs a running digital twin in the browser from a single GLB file. All component configuration is embedded in the GLB using the `rv_extras` (REALVIRTUAL) extension during Unity export, and the browser viewer reads this metadata to recreate the simulation, the 3D-HMI and the digital-twin links — no separate configuration files.
This page lists the Unity C# components that are exported and supported in realvirtual WEB, grouped by area. Component names in the browser match their Unity counterparts, so a scene authored in Unity behaves the same way in the browser.
Support is defined by the **rv-ODT v1** interchange schema. Everything below is read from the GLB and reconstructed automatically. Components not listed here are either Unity-only or belong to a runtime layer outside the interchange format (for example the in-browser DES engine and library behaviors).
## Motion & Drives
The `Drive` component and its drive behaviors are fully supported, including position, speed and acceleration control with limits.
| Component                            | What runs in realvirtual WEB                                                 |
| **Drive**                            | Linear (X/Y/Z) and rotational motion, limits, acceleration, current position |
| **Drive\_Simple**                    | Jog forward/backward with speed and position feedback                        |
| **Drive\_Speed**                     | Speed-controlled motion from a PLC target-speed signal                       |
| **Drive\_DestinationMotor**          | Point-to-point positioning (start → destination) with feedback               |
| **Drive\_FollowPosition**            | Drive directly follows a PLC position signal (scale + offset)                |
| **Drive\_Cylinder**                  | Two-position pneumatic cylinder with end-position feedback                   |
| **Drive\_Gear**                      | Slave a drive to a master drive with gear ratio and offset                   |
| **Drive\_PositionSwitch**            | Bool output while the drive is inside configured position areas              |
| **Drive\_ErraticPosition**           | Random / alternating motion between min and max                              |
| **DrivesRecorder / ReplayRecording** | Record and replay drive motion sequences, signal-triggered                   |
{% hint style="warning" %}
`Drive_CAM` (cam-disc coupling) is reserved in the schema and is **not** simulated in realvirtual WEB yet.
## Kinematics & Robotics
| **Kinematic** | Kinematic hierarchy re-parenting (integrate group / kinematic parenting, hierarchy simplification) applied on load |
| **RobotIK**   | Inverse-kinematics solver configuration on the robot root (spherical / non-spherical wrist)                        |
| **IKPath**    | Ordered list of IK targets forming a robot path, with start/end signals and looping                                |
| **IKTarget**  | Target pose, interpolation and blending, pick/place configuration                                                  |
## Transport & Material Flow
| **TransportSurface** | Conveyor surface moving MUs along a direction at the referenced drive's speed; accumulation and radial turntables |
| **Source**           | Spawns MUs by interval or distance and places them on the transport system                                        |
| **Sink**             | Destroys MUs that reach it        |
| **MU**               | Movable-Unit template that the Source clones        |
| **Grip**             | Pick-and-place gripper (1-bit or pick/place signals, auto / static / physics place modes)                         |
| **GripTarget**       | Snap / align marker for precise MU placement        |
| **Path**             | Arc-length path for path-based movement (AGV / overhead conveyors); line and arc segments with graph chaining     |
## Sensors
| **Sensor** | Presence sensor (AABB overlap or raycast); occupied / not-occupied PLC signals |
## Signals & Logic
| **PLC Signals**   | `PLCInputBool/Float/Int` and `PLCOutputBool/Float/Int` are registered in the browser SignalStore and drive all components        |
| **ConnectSignal** | One-way signal bridge that copies a source signal onto its own signal        |
| **LogicStep**     | Sequencing steps: serial / parallel containers, delay, set/wait signal (bool & float), wait for sensor, drive-to / start-drive / set-drive-speed, wait for drives at target, enable, grip pick / place, IK path, jump on signal |
Live signals arrive over WebSocket, MQTT or REST and always override local behavior immediately. Signal direction follows the PLC convention — PLC Outputs are read by the viewer, PLC Inputs are written by the viewer.
## 3D-HMI
Marker components authored in Unity that build the browser-based 3D-HMI. For field-level details and authoring workflow see [Building a 3D-HMI](/extensions/realvirtual-web/3d-hmi.md).
| **WebSensor**                  | Signal-bound status indicator with Low / High / Warning / Error states (ISA-101 colors, blink) and optional label                |
| **WebError**                   | Bool-signal error state: 3D badge + entry in the message panel; configurable highlight                                           |
| **WebVisibility**              | Show / hide parts from a bool signal, plus an optional error state                                                               |
| **WebSafetyDoor**              | Safety-door overlay with hazard-zone halo and label        |
| **CustomRuntimeInstruction**   | Signal-activated operator instruction: multi-step, per-step 3D highlight / isolate, optional document link                       |
| **RuntimeMetadata**            | Tooltip / annotation content (article numbers, descriptions) shown on hover and used for document linking                        |
| **WebDiagnostics** *(preview)* | Couples a PLC error signal to AI error diagnosis — currently a realvirtual WEB feature; the Unity authoring component is planned |
Message panels, KPI dashboards and drive / sensor tooltips are provided by realvirtual WEB itself and are driven by the components above and by live signals.
## Digital Twin Integration
| **AASLink** | Links a part to an Asset Administration Shell (AASX from a local folder or a server URL); shows Nameplate and Technical Data as a tooltip |
| **CADLink** | CAD-import provenance metadata and in-browser re-import        |
## Scene & Structure
| Component / feature             | What runs in realvirtual WEB                                                  |
| **Group**                       | Named group membership drives visibility groups                               |
| **WebPivot**                    | Explicit pivot point for a library object (used at import / placement time)   |
| **Connections**                 | Self-describing typed connections (for example sensor → station stop-on-exit) |
| **Camera presets, Measurement** | Provided by the viewer at runtime (camera views, distance measurement)        |
## Extensibility
| Feature                            | What runs in realvirtual WEB        |
| **WebComponent (GLB-embedded JS)** | Sandboxed `setup(self)` behavior scripts embedded in the GLB, executed in a secure in-browser sandbox (opt-in) |
## See Also
* [realvirtual WEB](/extensions/realvirtual-web.md) — export and publish workflow
* [Building a 3D-HMI](/extensions/realvirtual-web/3d-hmi.md) — authoring the `Web*` 3D-HMI components in Unity
GET https://doc.realvirtual.io/extensions/realvirtual-web/supported-components.md?ask=<question>&goal=<user_goal>
