# Page Not Found
The URL `components-and-scripts/snap-points` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Sensors](https://doc.realvirtual.io/components-and-scripts/sensors.md)
- [Motion and Kinematic](https://doc.realvirtual.io/components-and-scripts/motion.md)
- [Interfaces](https://doc.realvirtual.io/components-and-scripts/interfaces.md)
- [Picking and Placing MUs](https://doc.realvirtual.io/components-and-scripts/picking-and-placing-mus.md)
- [Machining Tool (Pro)](https://doc.realvirtual.io/components-and-scripts/machining-tool.md)
GET https://doc.realvirtual.io/components-and-scripts/sensors.md?ask=<question>&goal=<user_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/components-and-scripts/sensors.md`).
