# Page Not Found
The URL `components-and-scripts/scene-interaction/hmi-components/hmi-value` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [HMI Value (Deprecated)](https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-value.md)
- [HMI Tab (Deprecated)](https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-tab.md)
- [HMI Slider (Deprecated)](https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-slider.md)
- [HMI Text (Deprecated)](https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-text.md)
GET https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-value.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/components-and-scripts/scene-interaction/hmi-components-pro/hmi-value.md`).
