> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-text.md).
# HMI Text
HMI Value is displaying texts for example identification codes or general information.\
The example below shows texts with the overlay option (BMK tags) and tags with a canvas in render mode "Worldspace" including the follow camera option.
<figure><img src="/files/q31UaZEzBFiEXhSKBZNE" alt=""><figcaption></figcaption></figure>
## Properties
<div align="left"><figure><img src="/files/BzCKcWfAUxPunvX8MU6G" alt=""><figcaption></figcaption></figure></div>
* `Text:` user defined text
* `Text Font Size:` font size of the text
* `Signal Activate Information:` PLC-signal to set the text active
* `Follow Camera:` text orientation follows the camera (only relevant in canvas render mode "WorldSpace"
* `Object Tracking:` activates the object tracking
* `Tracked Object:` tracked Object of the HMI-Text
* `Offset:` position offset
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://doc.realvirtual.io/components-and-scripts/scene-interaction/hmi-components-pro/hmi-text.md?ask=<question>&goal=<endgoal>
