> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/components-and-scripts/robot-program-export.md).
# Robot Program Export (Pro, Beta)
Robot Program Export is only included in realvirtual Professional.
{% hint style="warning" %}
**Beta feature.** The generated output is a **copy-paste template**, not a complete, ready-to-run robot program. Always load and validate the code on a (virtual) controller before running it on real hardware, and start at a reduced speed override. Tool, base/work-object, frame and I/O addressing stay your responsibility on the controller.
This feature was added in realvirtual **6.3.4** (Professional).
Robot Program Export turns a robot path you teach in realvirtual ([Robot Inverse Kinematics](/components-and-scripts/robot-inverse-kinematics.md)) into ready-to-paste controller code. It reads the targets of an **IK Path**, re-solves each one, and generates the axis angles and Cartesian poses as a program template for the major robot controllers.
This is an **offline** helper for virtual commissioning: there is no live connection and no automatic upload to the controller. You generate the text, copy it (or save it to a file), and paste it into the controller's program editor.
<figure><img src="/files/JcVMTRt0Vg47bGkQq1GV" alt="Robot Program Export window with the target dropdown open, a monospace code preview, and the IK Path inspector export button"><figcaption><p>Robot Program Export window with live preview, next to the IK Path inspector button</p></figcaption></figure>
## Important: it is a template, not a finished program
The export produces exactly **one instruction per IK Target** — it does not sample or interpolate the path between targets. The robot follows precisely the points and poses you defined.
What the template does **not** include (you complete this on the controller):
* Calibrated tool data, base / work-object and user frames (the export falls back to defaults such as `tool0` / `wobj0`, `TOOL_DATA[1]` / `BASE_DATA[1]`, `UFRAME 0` / `UTOOL 1`).
* Real signal addresses. Signal names from the path are written as comments; for KUKA and Fanuc a placeholder index is used (remap it on the controller).
* Safety logic, program flow and external-axis values.
The chosen template character is also written into the header of every generated file.
## Supported targets
| Target                   | Output                                             | Notes        |
| **ABB RAPID**            | `.mod` module                                      | `MoveAbsJ` (axis-based) or `MoveJ`/`MoveL` (Cartesian), `SetDO`/`WaitDI`, `WaitTime`        |
| **KUKA KRL**             | `.src` + `.dat`                                    | `PTP {E6AXIS}` (axis-based) or `LIN`/`PTP {E6POS}` (Cartesian), `$APO.CDIS`, `$OUT[]`/`WAIT FOR $IN[]`        |
| **Fanuc TP/LS**          | `.ls` (ASCII)                                      | Joint or Cartesian positions with `CONFIG` string, `J`/`L` moves, `DO[]`/`WAIT DI[]`. Compile to `.tp` in RoboGuide / `maketp.exe`        |
| **SEW MOVI-C / MOVIKIT** | `.csv` point table or `.st` (IEC 61131-3 template) | MOVIKIT Robotics is a PLC function-block framework, not a robot language — these are an importable point table and a Structured Text starting template, not a runnable program        |
| **Wandelbots NOVA**      | `.py` (NOVA Python SDK) or `.ws` (Wandelscript)    | `joint_ptp` / `cartesian_ptp` / `linear` / `io_write` executed via `plan_and_execute`. Positions in mm, orientation as a rotation vector (rad), joints in rad. The Python SDK is the recommended path; Wandelscript is deprecated by Wandelbots but still runs during the transition |
## Quick Start
1. Select your **IK Path** in the scene (the GameObject carrying the `IKPath` component).
2. Open the window via **Tools > realvirtual > Robot Program Export (Pro)**, or click **Export Robot Program (Beta)** at the bottom of the IK Path inspector.
3. Choose the **Target** controller from the dropdown.
4. Pick the motion mode (see below) and adjust the options.
5. Click **Preview** to generate the code and review it.
6. Click **Copy to Clipboard** to paste it into the controller editor, or **Save File…** to write it to disk (KUKA writes two files into a folder).
The status line shows how many instructions were generated and whether any warnings (unreachable target, gimbal lock, missing kinematics) occurred.
## Options
**Target** Selects the controller dialect: ABB RAPID, KUKA KRL, Fanuc TP/LS, SEW MOVI-C (CSV) or SEW MOVI-C (ST template).
**Axis-based (MoveAbsJ) – recommended** When enabled, joint moves are exported as pure axis targets (ABB `MoveAbsJ` + `jointtarget`, KUKA `PTP {E6AXIS}`, Fanuc joint-representation positions). This is unambiguous and avoids robot-configuration problems, so it is the recommended default. Turn it off for **Cartesian** output (`robtarget` / `E6POS` / `X,Y,Z + W,P,R`), which produces human-readable poses but requires correct configuration data. SEW always exports Cartesian.
**ABB: snap speed to predefined v####** When enabled, the linear speed is mapped to the nearest predefined ABB speed value (`v5 … v7000`). When disabled, a custom `speeddata` is emitted with the exact speed. Applies to ABB only.
**Include linked paths (StartNextPath)** When disabled (default), only the selected path's own targets are exported. When enabled, the export follows the `StartNextPath` chain and concatenates all linked paths into one program.
## Output modes
* **Axis-based (recommended)** — exact solved axis angles, one move per target, free of configuration ambiguity. Best for getting a path onto the controller reliably.
* **Cartesian** — TCP poses (position + orientation) with the derived robot configuration. More readable and editable on the controller, but you must verify the configuration (ABB `robconf`, KUKA `S`/`T`, Fanuc `CONFIG`) for your cell.
## Validating the generated code
Because there is no live connection, validate the output in the controller vendor's offline tool before deploying:
* **ABB** — RobotStudio (Basic edition is free): create a virtual controller and load the `.mod`.
* **KUKA** — WorkVisual (free, syntax check) and KUKA.OfficeLite (trial, runs real KSS/KRL). The export targets classic KSS/KRL.
* **Fanuc** — RoboGuide (trial): compile the `.ls` to `.tp` and run it in a virtual work cell.
* **SEW** — load the CSV point table in MOVISUITE; the ST template is a starting point for your PLC project.
A built-in forward-kinematics check inside realvirtual is the always-available first line of validation.
## Limitations
* **Beta** — the Cartesian configuration derivation can be wrong in edge cases; the axis-based mode is the robust path.
* **No live connection** — offline copy-paste only; no program upload (use the [robot interfaces](https://github.com/game4automation/doc/blob/doc/components-and-scripts/interfaces/README.md) for live coupling).
* **6 axes only** — external axes / positioners and multi-robot programs are not exported; ABB/KUKA external-axis fields are written as "not in use" (`9E9` / `E1..E6 = 0`).
* **No circular moves** — only point-to-point and linear moves are produced.
* **SEW is not a robot language** — MOVIKIT computes the inverse kinematics on the controller; only a point table / ST template is exported.
## Extending: custom postprocessors
The export uses an open architecture so you can add your own controller dialect or adapt an existing one. It has two layers:
1. **Conversion** — `IKPathToProgram.Convert(ikPath)` re-solves the path and produces a vendor-neutral `RobotProgram`: a list of `RobotMoveInstruction`s where the joint angles, the right-handed Cartesian position (mm), the rotation quaternion, the ZYX Euler angles, speeds, blend radius, signals and configuration flags are already computed once.
2. **Formatting** — a `RobotPostProcessor` subclass turns that model into controller text. The built-in ABB, KUKA, Fanuc and SEW postprocessors all share this base class.
All files live in `Packages/io.realvirtual.professional/Runtime/IK/Export/` (the base, model and converter) and `Export/Vendors/` (the per-controller postprocessors) — the existing vendor files are the best templates to copy.
### Create your own postprocessor
Subclass `RobotPostProcessor`, set the identity properties, and override the hooks you need. The base class drives the generation order (header → tool → frame → one `MoveJ`/`MoveL` per target plus its signals/dwell → footer) and writes everything into a shared `StringBuilder` (`AddLine(...)`):
```csharp
public class MyControllerPostProcessor : RobotPostProcessor
    public override string DisplayName => "My Controller";
    public override string FileExtension => ".txt";
    public override string GetFileName(RobotProgram prog) => prog.Name;
    protected override void Header(RobotProgram prog) => AddLine($"PROGRAM {prog.Name}");
    protected override void Footer(RobotProgram prog) => AddLine("END");
    protected override void MoveJ(RobotMoveInstruction m) =>
        AddLine($"PTP J=[{Fmt(m.JointAngles[0])}, ... ,{Fmt(m.JointAngles[5])}] v={Fmt(m.JointSpeedPct)}%");
    protected override void MoveL(RobotMoveInstruction m) =>
        AddLine($"LIN X={Fmt(m.PositionMm.x)} Y={Fmt(m.PositionMm.y)} Z={Fmt(m.PositionMm.z)} " +
                $"A={Fmt(m.EulerZYXDeg.z)} B={Fmt(m.EulerZYXDeg.y)} C={Fmt(m.EulerZYXDeg.x)} v={Fmt(m.LinSpeedMmS)}");
    protected override void SetDigitalOutput(string signal, bool value) => AddLine($"DOUT {signal}={value}");
    protected override void WaitDigitalInput(string signal, bool value) => AddLine($"WAIT {signal}=={value}");
    protected override void WaitTime(float seconds) => AddLine($"DELAY {Fmt(seconds)}");
Useful fields on each `RobotMoveInstruction`: `MoveType` (PTP / LIN), `JointAngles[6]` (deg), `PositionMm`, `RotationQuat`, `EulerZYXDeg` (`z`=A/Yaw, `y`=B/Pitch, `x`=C/Roll), `JointSpeedPct`, `LinSpeedMmS`, `LinAccelMmS2`, `BlendRadiusMm`, `EnableBlending`, `DwellSec`, `SetSignalName`, `WaitSignalName`, `PickPlaceSignalName` and the `Config` flags (`AbbConf`, `FanucTurns`, `Flip`, `Lower`, `KukaStatus`, `KukaTurn`). The static `RobotCoordConverter` provides the shared coordinate helpers (right-handed conversion, ZYX Euler, configuration flags).
For more control you can override:
* `Emit(RobotProgram)` — to produce **multiple files** (KUKA emits `.src` + `.dat` this way).
* `Generate(RobotProgram)` — to take over the **whole layout** (the ABB postprocessor collects declarations separately; the SEW postprocessors emit a CSV table / Structured Text directly).
### Register it in the window
Add your postprocessor to `RobotProgramExportWindow` (`Packages/io.realvirtual.professional/Runtime/IK/private/Editor/`): add an entry to the `VendorNames` array and a matching `case` in `CreatePostProcessor()`.
### Change an existing postprocessor
Edit the relevant file in `Export/Vendors/` (`ABBRapidPostProcessor.cs`, `KukaKrlPostProcessor.cs`, `FanucLsPostProcessor.cs`, `SewPostProcessors.cs`, `WandelbotsPostProcessors.cs`) — for example to change speed mapping, the program header, frame/tool defaults or the signal-address convention for your cell.
## See Also
* [Robot Inverse Kinematics (Pro)](/components-and-scripts/robot-inverse-kinematics.md)
* [Interfaces](https://github.com/game4automation/doc/blob/doc/components-and-scripts/interfaces/README.md)
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://doc.realvirtual.io/components-and-scripts/robot-program-export.md?ask=<question>&goal=<endgoal>
