> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/basics/login-and-download-updates-pro.md).
# Login & Download Updates (Pro)
Customers using the **Professional version** of realvirtual can access the **User Hub**, an in-app tool to manage your license, download updates, and activate the UPM registry.
The User Hub has four tabs: **News**, **Login**, **Downloads**, and **Packages**.
## Opening the User Hub
Access the User Hub from the Unity main menu:\
\&#xNAN;**`Tools > realvirtual > User Hub`**
Or via the realvirtual toolbar dropdown in the editor toolbar.
## Login
The **Login** tab offers two login methods, selectable at the top:
### Invoice + ZIP
Use this method if you purchased realvirtual directly or via the Unity Asset Store:
1. Select **Invoice + ZIP** as the login method
2. Enter your **Invoice Number** — a realvirtual invoice or Unity Asset Store invoice number
3. Enter your **Billing ZIP Code** — required for realvirtual invoices, leave empty for Unity Asset Store invoices
4. Enter your **Email** address
5. Check the **License Agreement** checkbox
6. Click **Login**
### Temporary License Key
Use this method if you received a **Partner Key** (`PK-XXXX-XXXX-XXXX`) or a **Temporary Code** (`SUB-XXXX-XXXX-XXXX-XXXX`) from your sales partner or license administrator:
1. Select **Temporary License Key** as the login method
2. Enter your key or code in the **Code** field
3. Enter your **Email** address
4. Click **Login**
Your license activates immediately. Keys and codes track concurrent sessions — when you close Unity, your seat is freed for others.
Temporary codes are generated by your license administrator via the [Customer Portal](/basics/customer-portal.md). Partner Keys are provided by your sales partner.
Once logged in, the **Account Status** shows **You are logged in** in green.
<figure><img src="/files/RKMWCiLFTzJFxITsKpVk" alt=""><figcaption><p>User Hub — Login tab with Invoice + ZIP method</p></figcaption></figure>
## Downloads
The **Downloads** tab lists all packages available for your license. Click **Refresh** to update the list.
Available packages include:
* **UPM packages** (`.tgz`) — For Unity 6 projects (e.g., `io.realvirtual.professional`, `io.realvirtual.starter`)
* **Legacy packages** (`.unitypackage`) — For older Unity versions
* **Archived versions** — Previous releases for backward compatibility
Click **Download** next to any package to download it.
<figure><img src="/files/uGGRxegcQLVc1vXNIelo" alt=""><figcaption><p>User Hub — Downloads tab with available packages</p></figcaption></figure>
## Packages
This feature was added in realvirtual **6.3**.
The **Packages** tab manages the realvirtual UPM scoped registry for automatic package updates.
### UPM Registry
After logging in, click **Activate Registry** to configure the realvirtual scoped registry in your project. Once active, the status shows **Active** in green along with the current channel.
Select a **Channel**:
* **Stable** — Production-ready releases
* **Beta** — Early access to upcoming features
### Installed Packages
Click **Check for Updates** to see if newer versions are available on the registry.
### What's New
Shows the latest package versions available on the registry. Click **Release Notes** to open the full release notes in your browser.
<figure><img src="/files/VgtLsJoMD0cjZlXsFWA4" alt=""><figcaption><p>User Hub — Packages tab with UPM registry and channel selection</p></figcaption></figure>
Once the registry is activated, realvirtual packages also appear in **Window > Package Manager** under "My Registries" and can be updated like any other UPM package.
## News
The **News** tab displays release notes and information about new features for each version. It appears automatically once when you start the Unity Editor.
Each release entry includes a summary of new features, improvements, and bug fixes along with a **Release Notes** button linking to the full documentation.
<figure><img src="/files/2Fi4S86vzEae2wO0n3MM" alt=""><figcaption><p>User Hub — News tab with release information</p></figcaption></figure>
## See Also
* [Customer Portal](/basics/customer-portal.md) — Web-based license management, temporary code generation, and invoice access at [download.realvirtual.io](https://download.realvirtual.io)
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://doc.realvirtual.io/basics/login-and-download-updates-pro.md?ask=<question>&goal=<endgoal>
