> For the complete documentation index, see [llms.txt](https://doc.realvirtual.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://doc.realvirtual.io/basics/folder-structure.md).
# Folder structure
Starting with version **6.3**, realvirtual is distributed as **UPM (Unity Package Manager) packages**. The folder structure changed significantly from the previous `Assets/realvirtual/` layout used in 6.0 and earlier.
## Package Overview
<figure><img src="/files/VmNfW2FesIYRqI2Okn8N" alt=""><figcaption><p>realvirtual UPM package structure</p></figcaption></figure>
realvirtual is split into two UPM packages:
| Package                         | Location                                | Description                                                           |
| **io.realvirtual.starter**      | `Packages/io.realvirtual.starter/`      | Core framework — drives, sensors, signals, transport, gripping, logic |
| **io.realvirtual.professional** | `Packages/io.realvirtual.professional/` | Professional add-on — IK, CADLink, interfaces, multiplayer, and more  |
{% hint style="warning" %}
UPM packages are **read-only** in Unity. You cannot edit files inside `Packages/`. Place your own scenes, scripts, and assets in the `Assets/` folder.
## Starter Package Layout
The Starter package (`Packages/io.realvirtual.starter/`) contains:
| Folder                  | Description        |
| **Assets/**             | User-facing assets you drag into scenes        |
| Assets/3DPrefabs/       | Industrial 3D models (conveyors, robots, boxes, fences)                                                          |
| Assets/Materials/       | Industrial materials (plastics, metals, lamp indicators)                                                         |
| Assets/Prefabs/         | Core functional prefabs (realvirtual.prefab, signal prefabs, interfaces)                                         |
| Assets/UIPrefabs/       | Runtime UI overlay prefabs        |
| Assets/Settings/        | Editor gizmo options, camera presets        |
| Assets/RenderPipelines/ | URP pipeline configuration and settings        |
| **Runtime/**            | All runtime C# scripts (components, behaviors, interfaces)                                                       |
| **Editor/**             | Editor tools, inspectors, and toolbar        |
| **Samples\~/**          | Demo scenes — import via [Demo Scenes Browser](/basics/user-interface/demo-scenes-browser.md) or Package Manager |
## Professional Package Layout
The Professional package (`Packages/io.realvirtual.professional/`) contains:
| **Runtime/**             | Pro features organized by domain        |
| Runtime/IK/              | [Robot Inverse Kinematics](/components-and-scripts/robot-inverse-kinematics.md) + robot prefabs       |
| Runtime/Interfaces/      | All Pro [interfaces](/components-and-scripts/interfaces.md) (OPC-UA, TwinCAT, KUKA, UR, Modbus, etc.) |
| Runtime/CADLink/         | [CAD file import](/basics/cad-import.md)                                                              |
| Runtime/PathTracer/      | Motion trail visualization        |
| Runtime/Statistics/      | Simulation statistics        |
| Runtime/Multiplayer/     | Multi-user networking        |
| Runtime/HighlightSystem/ | Object highlighting and selection        |
| Runtime/DistanceSystem/  | Distance measurement and connectable objects                                                          |
| **Editor/**              | Pro editor tools        |
| **Samples\~/**           | Pro demo scenes (PLC Interfaces, Robotics, Robot Interfaces, Advanced Features)                       |
## Key Asset Locations
When setting up scenes, you will frequently need these assets:
| What you need           | Where to find it        |
| Main framework prefab   | `Packages/io.realvirtual.starter/Assets/Prefabs/realvirtual.prefab`                                                       |
| Industrial 3D prefabs   | `Packages/io.realvirtual.starter/Assets/3DPrefabs/`        |
| Materials library       | `Packages/io.realvirtual.starter/Assets/Materials/`        |
| PLC signal prefabs      | `Packages/io.realvirtual.starter/Assets/Prefabs/`        |
| Interface prefabs (Pro) | `Packages/io.realvirtual.professional/Runtime/Interfaces/<Name>/`                                                         |
| Robot prefabs (Pro)     | `Packages/io.realvirtual.professional/Runtime/IK/`        |
| Demo scenes             | Import via [Demo Scenes Browser](/basics/user-interface/demo-scenes-browser.md) or **Window > Package Manager > Samples** |
## Your Project Content
Place all your project files in `Assets/`:
* **Scenes** — your simulation scenes
* **Scripts** — custom C# scripts and behaviors
* **Prefabs** — your own reusable prefabs
* **Materials** — custom materials
* **Imported CAD data** — files imported via CADLink
## Previous Folder Structure (6.0 and earlier)
In versions before 6.3, realvirtual was distributed as a `.unitypackage` installed into `Assets/realvirtual/`. This folder no longer exists in UPM-based installations. See the [Upgrade Guide](/advanced-topics/upgrade-guide.md) for migration instructions.
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://doc.realvirtual.io/basics/folder-structure.md?ask=<question>&goal=<endgoal>
